Pages: [1] 2 3  All   Go Down
Author Topic: Reading Fault Codes 2.0 2000  (Read 8561 times)
OpelJay
  • If in doubt, Flat out.
    • Omega CD 2.0 duelfuel
« on: 04 July 2012, 19:13:57 »
HI, can anyone help me ive been having some trouble with my EML coming on and off at random times...
Theres no real issue with the car perhaps maybe running a bit sluggish? tried the normal stuff cleaning checking connecters..?
I took it upon my self to do a paper clip test but getting some confusing results. Id be great full of any help :(
6 / 9 / 10
10/ 1 / 3 / 10
10/ 5 /10 / 5
10 / 1 / 1 / 9
10 / 2 / 10 / 1
10 / 2 / 10 / 2
Re: Reading Fault Codes 2.0 2000
« Reply #1 on: 04 July 2012, 19:24:07 »
Can you double check the codes, wondering if there is a misread in there :)
OpelJay
« Reply #2 on: 04 July 2012, 20:01:40 »
1 6 9 10 thats the first one
OpelJay
« Reply #3 on: 04 July 2012, 20:32:47 »
i think the 10 is a 0?
« Reply #4 on: 04 July 2012, 20:36:32 »
2.0 error codes are here .... (4 digit ones as you list .. older ones have 2 digit codes )
http://www.omegaowners.com/forum/index.php?topic=90583.0
HTH
OpelJay
« Reply #5 on: 04 July 2012, 20:47:41 »
HTH
what do they mean???
« Reply #6 on: 04 July 2012, 20:50:57 »
HTH
The code number tells you the fault as read from that list, ignoring the "P" ........ so you look up 1690 and it tells you the possible fault(s) ....
OpelJay
« Reply #7 on: 04 July 2012, 20:58:48 »
could i get most of these faults due to a faulty battery? ive just put new one on???
OpelJay
« Reply #8 on: 04 July 2012, 21:01:49 »
how do i clear the ecu? then run for a day see what faults throw up?
OpelJay
« Reply #9 on: 04 July 2012, 22:01:06 »
 :( hello?
Steve B
  • Leicestershire
    • '52' MV6 3.2 Saloon
« Reply #10 on: 04 July 2012, 22:11:41 »
to do that you will need a code reader
OpelJay
« Reply #11 on: 05 July 2012, 06:20:16 »
i tought there was a way to do it with out computer?
dad1uk
  • Birmingham
    • Vauxhall Zafira 2.2
« Reply #12 on: 05 July 2012, 08:04:39 »
If it was the battery and that has been replaced then after a few clean starts the faults will be cleared on its own. The only other way is with a code reader.
best wishes
Simon.
OpelJay
« Reply #13 on: 05 July 2012, 13:32:10 »
the new battery has helped but i still get a eml come up i drove the car for a hour like and it was fine soon as i was idling the eml come on so ive took the time to by a brand new idle control valve and a throttle position sensor hope this will help
OpelJay
« Reply #14 on: 06 July 2012, 16:42:57 »
put new idle control valve on still no difference car ant running very well and seems when you press the cluch in and start to role revs stay at 1500 - 2000 then when you completely stop they settle back to normal??? could it be the TPS?
Pages: [1] 2 3  All   Go Up
