Author Topic: Elite Estate Boot Cubbyholes wanted  (Read 5968 times)
« on: 06 September 2012, 16:29:59 »
Hi, I am after the pair of plastic 'trims' to form cubbyholes over the wheel arches in the boot of an estate.
They were only fitted to some elite's by defaults as far as I can tell.
In a dark colour, not cream please.
Thanks
LFF64
  • HADDENHAM BUCKS
    • 64 insignia CT Nav 4x4
Re: Elite Estate Boot Cubbyholes wanted
« Reply #1 on: 07 September 2012, 17:25:00 »
I thought you had some Jimbob AndyC can get them I think its about £100 for the pair
« Reply #2 on: 07 September 2012, 18:27:23 »
I had some....have fitted them to mine, the other car would now like a set...but not at £100!
« Reply #3 on: 07 September 2012, 23:41:44 »
They are very handy things, think PFL are same?
« Reply #4 on: 08 September 2012, 07:35:10 »
yes, seem the same through the range, or minimal difference anyway
kcl
  • Finland
    • Volvo V60 D4 -14
« Reply #5 on: 14 September 2012, 09:15:35 »
AFAIK fitted to all estates with BOSE due BOSE filling the storage rooms on sides of boot. I'm also after them, seem to be very difficult to get.
« Reply #6 on: 14 September 2012, 10:09:42 »
You could be right, EPC does mention 'with sound system'
omegod
  • liverpool
    • 2017 Seat Ateca
« Reply #7 on: 17 September 2012, 14:38:54 »
I don't know what these look like Jimbob but i'm happy to keep my eye out at the scrappy's next weekend if you have a pic?
twiglet
  • Norwich, Norfolk
« Reply #8 on: 17 September 2012, 14:45:03 »
The parts Jimbob wants ate the plastic bits above each rear wheelarch...  :y
« Reply #9 on: 17 September 2012, 14:45:15 »
cheers, the plastic 'boxes' over the wheel arches like these....
secured with one or 2 bolts accessible through the panels, and the other end needs 1 screw removing to release the trim, and 1 bolt for the seat securing catch then you can get at the one bolt on the other end.
« Last Edit: 17 September 2012, 14:46:52 by Jimbob »
waspy
« Reply #10 on: 17 September 2012, 19:34:23 »
Mine has Bose & the little plastic storage compartments, so "SOUNDS" about right ;D :-[ Sorry
kcl
  • Finland
    • Volvo V60 D4 -14
« Reply #11 on: 24 September 2012, 06:24:20 »
I AM right, I just know it.  :P They were designed and fitted to replace the lost storage rooms due the BOSE equipment being in the cubby holes on both sides.
MV6Matt
  • London
    • No car since 2022....
« Reply #12 on: 25 September 2012, 14:54:59 »
They are very useful.....
Aren't they a pain to fit, involving taking out and replacing loads of trim and carpet?
Is it an easy fix?
(thanks Ian)
« Reply #13 on: 25 September 2012, 15:50:19 »
Is it an easy fix?
nope, fit over carpet, quite easy
MV6Matt
  • London
« Reply #14 on: 01 October 2012, 17:08:11 »
Is it an easy fix?
But the attaching screws have to come from the 'outside -in' (through the carpet) don't they?  ??? That involves taking the trim out I understand
(thanks Ian)
