Author Topic: Maintenance Guide Index  (Read 185176 times)
    • E250 Est / Elroq
« on: 23 November 2009, 19:16:18 »
Read before following any guides
Obviously safety is paramount. These guides are all written by members who have done the jobs themselves, none of whom are professional technical authors. Therefore, they are to be read on the merit of items that will assist you rather than a precise 'follow this to the letter' type guide.
Whilst every care is taken to ensure the accuracy of these guides, you should satisfy yourself that they are applicable to your vehicle, you have the necessary skills to carry out the task and that you follow the usual safety procedures associated with working on any car. That is, you secure the vehicle using brakes, chocks and wedges where necessary and that you NEVER work on an car supported only by jacks. Always use axle stands positioned appropriately.
If you have any doubts regarding safety, ask BEFORE you attempt any job on your vehicle.
None of these guides are endorsed by the owners or administrators of this forum. You follow any of these guides at your own risk
« Last Edit: 16 October 2011, 09:04:27 by Jimbob »
    • E250 Est / Elroq
Re: Maintenance Guide Index
« Reply #3 on: 23 November 2009, 19:17:57 »
Engine : Petrol
V6
V6 Aircon Compressor Replacement
V6 Oil Change
V6 Coolant Temperature Sensor (CTS) Change
V6 Plenum Removal
V6 Plenum removal - Extra info & some close-ups
Tips on removing coil packs without damage
V6 Torque Values
V6 Camshaft identification
V6 Engine bay vacuum pipes
V6 Multiram operation
V6 Cambelt change - Novice View + DVD Available
V6 Spark Plugs Change 2.6/3.2 (2.5/3.0 similar)
V6 DIS Pack Replacement (and HT Lead connection Diagram)
V6 Crank Sensor Replacement
V6 Thermostat Replacement (3.2 Engine) with videos etc
V6 Cleaning Crankcase Breather System
V6 Changing the Oil Cooler
V6 Oil Cooler Replacement Parts and Part Numbers
V6 Changing the Cam Cover Gaskets
V6 Head Gasket Change
V6 Replace Aircon condenser
V6 Change Heater Bypass Valve (HBV)
V6 ABS ECU Replacement - Speedo not working; ABS/ TC lights on .
V6 ABS ECU Replacement - Alternative method
V6 JSeamen's Engine Rebuild Guide (WIP)
V6 (2.6/3.2) Moving Lambda / O2 Sensors to cure P0420/P0430
V6 Throttle Body Port & Polish
V6 Starter Motor Replacement
V6 Engine removal Guide
4 Cylinder
2.0/2.2 Torque Settings
2.2 Spark Plug Change
2.2 Cleaning the EGR
2.0 Cleaning Your IACV and Breather Jet
2.0 Cleaning the throttle valve assembly Omega 2.0 16V
2.0 Cleaning X20XEV Idle Control Valve
2.0 and 2.2 Cam cover gasket replacement
2.2 Replacing Cam Cover Gasket
2.0 Cam Cover Replacement
2.2 Drive by Wire Throttle Body and Breathers
2.2 Oil Change
2.2 Cam Sensor Change
2.2 Coolant Flush
2.2 Head Gasket / Cambelt Change
2.2 Crank Sensor
« Last Edit: 19 March 2017, 20:14:32 by Jimbob »
    • E250 Est / Elroq
« Last Edit: 16 September 2012, 20:27:55 by Jimbob »
    • E250 Est / Elroq
« Reply #6 on: 16 September 2012, 20:27:01 »
ICE / Electrical
Audio & Entertainment
Laser replacement guide for NCDxxxxx stereos
Guide for fixing radio in 'Safe' mode
CID LCD Panel Replacement
TID / MID Duff Pixel Repair - External site link
Facelift CD Changer Repair
Changing radio display digits
How to fit line level outputs to a CCR2006
Wiring in an amp
Removing a facelift (double din) radio
Internal Electrics
Hillpers Boot Mod. (facelift cars)
Fit a total closure kit
Resetting one touch window function.
Climate bulb renewal (Prefacelift)
Remove cloth seat, heater pads
Replacing the front central locking motors.
Repairing a central locking motor
Change Non-Climate Heater Control Bulbs
Ignition switch and connector removal
Ignition lock re-condition
Removing the ignition lock assembly
Aircon working only Passenger side
Aircon working only Drivers side
Cleaning the sunroof switch
Replace your high level brake light
Replace Your Heater Motor
Replace your SRS (airbag) ECU
Fix your wing mirror adjustment switch
Swap your TID to a MID
Remove rear 12v socket
External Electrics
Disconnect the Battery
Removing An Omega headlight
Headlight Cluster Lamp Replacement Guide
Replace Your Headlight Adjusters
Removing Headlight lenses
Diagnose issues with Park Pilot reversing sensors
Fit aftermarket rear parking sensors
Fit aftermarket rear parking sensors - Alternate version
Aftermarket parking sensor positioning
Inside The Powersounder
Power sounder disconnection
Battery, Charging and Starting Diagnosis
Repairing the Alternator
V6 Alternator Replacement
Replacing a fan switch - V6
TD - Fitting Performance Chip
Fitting a new / performance ECU Chip
Retrofitting Features
Retrofit Rain Sensitive Wipers
Retrofit A Variable Delay Wiper Stalk
Retrofit Carin Sat-Nav
Fitting auto dipping mirror by Hillper
Fitting prefacelift cruise howtoo
Retrofit Cruise Control (DBW cars only)
Fitting Cruise (Facelift Only)
Fitting Elite Seats to Other Models
« Last Edit: 19 March 2017, 21:17:11 by Jimbob »
    • E250 Est / Elroq
« Reply #7 on: 16 September 2012, 20:29:28 »
Trim, Cosmetics & Body
Internal
Retrofit an Air conditioned glovebox
Fix your facelift Ashtray
Removing the rear centre seatbelt from an estate
Replace you facelift aircon buttons
Remove the Headlining
Neatly install a Tom Tom
Replace your glovebox handle (covers glovebox removal)
Remove / replace the centre console trim
Removing the instrument panel
How to Remove Clocks Panel
Centre dash panel removal
Rear blind removal
Freeing Off The Seat Height Adjuster
Fitting an adjustable steering column
How to gain access to the side airbag
Replacing Door Strap Bush
How to repair front door check strap (with pics)
Prefacelift door card removal
Door Card Removal - Facelift
pre-facelift & facelift door lock replacement
How to Replace Corroded Fuel Pump Cover Plate
Window winder mech replacement
External
Replace the aircon High Pressure Valve
Removing Wipers and Scuttle
Fix Wiper Parking
Remove your front bumper (Facelift)
Dissasemble Your Door Mirror
Retro Fit Insignia 'fan pattern' windscreen washer nozzles to your omega
Refurb your cloudy headlight lens
Replace your Heater Matrix (Cheat method)
Flushing your Heater Matrix
Adjusting the bonnet catch (when pulling the lever doesnt quite work)
Replacing the bonnet catch spring (when the above guide doesnt quite work)
Getting Under The Bonnet (cable snapped / handle broken etc)
Retrofitting Facelift Door Rubbing Strips
Scuttle Drain Cleaning
Removing wiper scuttle
How to clean out your scuttle drain.
Cleaning windscreen washer system
Door trims
Replacing Rear Chrome Trim and Bumper Supports
Rear Bumper removal How To
Remove Sunroof Glass Panel
Aerosol Spraying
Reducing wind noise
« Last Edit: 18 June 2014, 10:26:50 by Jimbob »
    • E250 Est / Elroq
« Reply #9 on: 16 September 2012, 20:32:48 »
    • E250 Est / Elroq
« Reply #10 on: 16 September 2012, 20:33:21 »
Submitting Guides
This section is by no means complete.
There is always room for new, or improved guides (just because we have a guide, it does not mean it is the best way to do a job, if you know a better way, please create a guide, likewise if you feel a guide is 'missing' feel free to create one).
If you would like to add to this section, please create your guide in the test section, from there we can copy it across, add to the index, and add some copy protection to any photos.  You can either add photos using photobucket etc, or you can email them to the address in my signature.  Photos will be moved onto the OOF servers.
If we see what we consider to be useful posts, we may request you make them into a how to, obviously there is no pressure to do this.
Thanks to all our contributors, past, present and future  :y
