Pages: [1] 2 3  All   Go Down
Author Topic: starting problem  (Read 11014 times)
Toledodude1973
  • IPSWICH U.K.
  • 2002 2.6 elite,1973 ,Gas van,1974 victor fe
    • 2.6 OMEGA ELITE 2002
starting problem
« on: 25 May 2013, 13:58:28 »
Hoping someone can  put their finger on this one. OK i had to take my Ommy off the road over winter due to being a bit strapped for cash, however i'm now planning to go back on the road 1st June, I charged the battery and it started second turn of the key so parked in driveway. The following day went to start it for MOT and only just started after nearly killing battery,passed MOT ok,but now only starts after about 6-7 turns of key then it runs fine. I seem to remember last year when turning ignition on it made a whirring sound as if something was powering up the noise is not apparent now .
Any ideas ,sorry for big blog but wanted to give whole story thank you
2002 omega slowly morphing into 2003 omega with increasing doner parts fitted
symes
  • oxford
    • R reg 940 volvo
Re: starting problem
« Reply #1 on: 25 May 2013, 14:47:18 »
remove/clean throttle body-also remove power sounder  :y
Toledodude1973
  • IPSWICH U.K.
« Reply #2 on: 25 May 2013, 15:02:48 »
Thanks for that is there a how to on here?
symes
  • oxford
    • R reg 940 volvo
« Reply #4 on: 25 May 2013, 20:59:50 »
Do the paperclip test (as per maint. guide) and post up the codes.Sounds like it might be yet another crank sensor.
« Reply #5 on: 25 May 2013, 21:01:22 »
2.6 Albs, pedal test ;)
« Reply #6 on: 25 May 2013, 21:25:49 »
Can't see throttle body causing that, as above read the codes, more likey a cam or crank sensor fault  :y
symes
  • oxford
    • R reg 940 volvo
« Reply #7 on: 25 May 2013, 21:47:06 »
been sat for ages- :y
« Reply #8 on: 25 May 2013, 21:48:23 »
And? Still can't see the connection. Left my 2.2 un-used for a year, fired back up no issues. 3.2 was once left for 5 months, same no problems there.
Toledodude1973
  • IPSWICH U.K.
« Reply #9 on: 26 May 2013, 09:05:03 »
Hello thanks for info its a 2002 2.6 can someone just run through pedal trick with me (slowly) sorry for being thick!
Toledodude1973
  • IPSWICH U.K.
« Reply #11 on: 26 May 2013, 09:37:35 »
thanks rob, i'm in the beast now pressed and holding down pedals, switch on and spanner flashes really fast with a slight pause now and then . Is quick flashing correct
Big_Al
« Reply #12 on: 26 May 2013, 09:50:58 »
should not be be so quick as you cannot count the flashes . It's a bit tricky & takes a bit of getting used to first time you attempt it .
I get SWMBO to sit in the passenger seat with a pen & paper & write down the numbers as I count them . Seems to work ;D ;D
another idea would be to video the sequence & play it back in slow-mo if you have that facility available   :-\  HTH  :y
« Last Edit: 26 May 2013, 09:53:27 by Essex Big Al »
Toledodude1973
  • IPSWICH U.K.
« Reply #13 on: 26 May 2013, 09:54:24 »
thanks Al, so i'm watching from first flash and wait for very slight pause, picture of engine also flashes..correct?
« Reply #14 on: 26 May 2013, 09:58:17 »
Nope, should only be the "spanner" light
Pages: [1] 2 3  All   Go Up
Page created in 0.021 seconds with 16 queries.
