Author Topic: Wanted: NCDR1100 - CID - CDCI3  (Read 5049 times)
asi_
  • Turkey
    • MV6 BFL
« on: 12 October 2013, 21:05:52 »
As above, i need NCDR1100 - CID - CDCI3. i use it for Omega Prefacelift
i am from istanbul/turkey.
MV6 BFL
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
Re: Wanted: NCDR1100 - CID - CDCI3
« Reply #1 on: 13 October 2013, 17:43:33 »
NCDR 1100 were never fitted to Omega's, believe they were from the Vectra and Astra family, so doubt many will have a set up on this site, you never know though.
The other thing I not sure about is whether they were Can Bus, if so then your probably going to have issues getting the Computer Info bit working, if not Can Bus then should work, but your probably still need to change the Engine Info in the configuration.  :-\
    • E250 Est / Elroq
« Reply #2 on: 13 October 2013, 17:48:32 »
I know at least one member running this in an omega, so definately doable :y
    • 530D M Sport, 330i Coupe
« Reply #3 on: 13 October 2013, 23:31:22 »
NCDR1100 / 1500 installation into a prefacelift is little more than installing a NCDC2011 / 2013 / 2015 into a facelift that previously didn't have one. Over and above you just have to decide where the CDC is going to reside and route the cabling to it.
asi_
  • Turkey
    • MV6 BFL
« Reply #4 on: 14 October 2013, 07:24:07 »
There is no problem mates :) if i found that parts it would be good.
MV6 BFL
« Reply #5 on: 14 October 2013, 10:09:28 »
The problem you have is NCDR1100 was never a standard fit here, we did have the CID's but they came with NCDC2013 or 2015.
You will probably have more luck on Astra/Vectra forums  :y
mindaz
  • IRL , UK
« Reply #6 on: 14 October 2013, 13:09:03 »
Vauxhall/0pel 0mega 2.5 , 2002 , CD
« Reply #7 on: 14 October 2013, 19:20:30 »
//TB strokes chin and wonders if he should sell this...
and the CDC3 and loom to convert CCR600/800 to NCDR/CID
No idea what its worth though.
« Reply #8 on: 14 October 2013, 23:38:48 »
What's the circuit board on the right of the units with the Cat5 by it?
« Reply #9 on: 15 October 2013, 19:08:14 »
Ah, remember the birds nest programmer? MkII ;)
