Author Topic: Opel Omega Fuel Pump Problems help me pleaaaaassseeeee  (Read 3594 times)
Addee-h
  • Sweden
    • Opel Omega
« on: 07 April 2014, 19:28:24 »
Hello! My name is Andreas and i have a problem with my car. It doesent start! I belive itīs the fuelpump however i do not know where it is? Can someone help me i need to fix it by tomorrow  :'( I bought the fuelpump this morning so if u can describe where it is i surely will find it, and if somebody knows, please explain to me as a child haha im so new with fixing cars. Itīs a Opel Omega 96, 2.5 engine, Manual...
Pleaaasepleaaaase help meeee! One love <3
davieboy0312
  • wishaw
    • 3l V6 saloon
Re: Opel Omega Fuel Pump Problems help me pleaaaaassseeeee
« Reply #1 on: 07 April 2014, 19:29:44 »
I think it is in the tank. lift boot carpet and there is a silver plate. lift that and it sits under there in the tank
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
« Reply #2 on: 07 April 2014, 19:33:45 »
Can admin move this to the relevant section for our Swedish friend ?
Addee, do the paperclip test first and report back with any codes found  :)
http://www.omegaowners.com/forum/index.php?topic=90581.msg1155463#msg1155463
Addee-h
  • Sweden
    • Opel Omega
« Reply #3 on: 07 April 2014, 19:40:25 »
Okay thank you guys so much i will check :)
Sorry if i was giving any problems!
Addee-h
  • Sweden
    • Opel Omega
« Reply #4 on: 07 April 2014, 20:10:27 »
Im so sorry, but i could not found it... Maybe I missunderstood everything... I found a silverplate in the trunk however no fuelpump...
davieboy0312
  • wishaw
    • 3l V6 saloon
« Reply #5 on: 07 April 2014, 20:16:55 »
if you remove the 4 screws holding the plate down. you will find a big black ring. loosen that off will take some moving. and pump is under that. might be worth checking fuses and purple relays in fuse box first though to make sure it is the pump
Addee-h
  • Sweden
    • Opel Omega
« Reply #6 on: 07 April 2014, 20:25:16 »
Ok so itīs under the trunk? not the back seat?
Andy89
  • Norway
    • 97 3.0 MV6
Addee-h
  • Sweden
    • Opel Omega
« Reply #8 on: 07 April 2014, 20:43:45 »
Man u are the best thank u so much one love <3 <3
Delroy47
  • Luton
    • 3.2 Elite Estate
« Reply #9 on: 09 April 2014, 07:05:50 »
Another happy customer ;D
  • Auckland
    • Mazda MPV
« Reply #10 on: 09 April 2014, 08:10:32 »
Why do you believe it is the fuel pump?
The fuel pump doesn't run until the ECU can see that the engine is running.
When you try to start the engine does the needle of the rev counter (tachometer) move at all? If it doesn't then you may have a problem with your crank position sensor (CPS)
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« Reply #11 on: 09 April 2014, 10:08:32 »
Pull off and check the fuel pipes by the side of the Penlium to check for fuel flow / pressure, before you start ripping the fuel pump apart.
You should be able to hear the pump prime when you turn on Ing.
« Reply #12 on: 09 April 2014, 19:50:48 »
Moved to help section for better visibility
