Pages: [1] 2 3  All   Go Down
Author Topic: changing the battery location..  (Read 6170 times)
« on: 11 April 2014, 17:36:24 »
I'm planning to change the battery location .. probably to boot..
what problems I may face.. any opinions welcome :y
Bigron
  • Witham, Essex
    • Omega 2.6 V6 Auto '51 Reg
Re: changing the battery location..
« Reply #1 on: 11 April 2014, 17:56:36 »
Why?
Apart from the need for hefty leads to minimise voltage drop, unless you opt for a sealed battery you will obviously need to consider possible spillage, fumes/acid vapour and the like. I'm sure there are other factors that Oofers will come up with, too......
Ron.
« Reply #2 on: 11 April 2014, 18:00:02 »
... Not least where and how to mount it securely  :-\
« Reply #3 on: 11 April 2014, 18:13:41 »
Why?
Ron.
thanks Ron :y
the reason is using some different aparats  and need space.. :-\
« Reply #4 on: 11 April 2014, 18:14:55 »
yep.. thats another question :-\
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #5 on: 11 April 2014, 18:33:28 »
Batteries have been boot mounted in rally cars for years, 5mm/6mm cable, and a short length or a good strap for the earth, a battery box nob jobbed.
Hoof'land storeman.
« Reply #6 on: 11 April 2014, 18:37:01 »
Thanks biggriffin.. details noted :y
biggriffin
« Reply #7 on: 11 April 2014, 18:41:59 »
If using a wet battery make sure the box is vented,by a length of pipe/hose to outside.
Hoof'land storeman.
« Reply #8 on: 11 April 2014, 18:56:03 »
using ac delco , not sure they are wet or anything else :-\
« Reply #9 on: 11 April 2014, 18:58:14 »
google search shows that they must be wet as dry batteries are very expensive ???
and I must also use a battery mat..
« Reply #10 on: 11 April 2014, 21:56:04 »
The battery in my Jag is in the boot (as standard) - no issues day to day, but downsides . . . would be a pain in the arse to change as fitted under boot floor next to spare wheel, so empty boot, lift floor, and battery itself is huge (354x175x190mm) and weighs 25Kg, and is awkward to reach!!! :-\
« Reply #11 on: 11 April 2014, 22:31:33 »
Not as bad as having to remove the driver's seat  ???
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
« Reply #12 on: 11 April 2014, 22:39:13 »
I was waiting for you to comment ;)
other rides
« Reply #13 on: 11 April 2014, 23:04:43 »
Having the battery in the boot is very handy when your battery dies in the car wash queue.  ::)
Jump leads straight to the car behind and I was in the wash, left the engine running during the wash and I was away!  :y
The bird in the car behind was a bit arsey about it though.  ::)  ;D
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« Reply #14 on: 11 April 2014, 23:53:35 »
The older BMW 3 series and M series, to name a few had the Batteries in the Boot, from memory some were the same size / spec as the Omega's (065) but with a vent tube from the top of the battery, Some 065 Battery's come with the vent hole plugged, so a tube can be inserted to go the the boot floor, see pics below.  ;)
Also worth considering having a additional Positive Jump Point, wired directly to the starter motor and good Engine Earth point in the Engine Bay, for two reasons, 1, so you dont have to empty the Boot to jump Start your Car, and 2, a shorter lead resistance to the Starter Motor when your rear Battery is flat. Again you can get the Engine Bay parts from a BM, Jeep, Porshe etc, see last Pic  :y
Pages: [1] 2 3  All   Go Up
Page created in 0.031 seconds with 16 queries.
