Author Topic: Zafira Engine Vibration  (Read 4546 times)
« on: 09 July 2018, 21:11:25 »
my Z19DTH Zafira's engine is shaking a bit, when idling, which is transmitted to the cabin, and is annoying.
It was there before Exhaust fell off, and Clutch leaked and got replaced.  Its still there now, and I think its worse.
Following an unrelated noise which has been resolved by the garage who did the clutch (tightening something) they advised engine mounts shot, so Ive added powerflex inserts to them, which has changed the noise, and supported the engine much better.  Does seem to transmit the vibration more though.
Following a good look, Ive noticed the below - Injection Quantity Deviation seems to show a possible injector issue
I beleive the 1st 2 arent far enough out to worry about, and I think no4 with the minus figure is the ecu trying to even out from cyl3.
So what to do?
Is some sort of fuel system / injector cleaner worth a shot?
Or should I chuck another one on?  Think Ive got one in the spares pile, but no idea on the procedure to change?  gather i need to program its number in too?
Or any other ideas?
tigers_gonads
  • Kinston Upon Hull
  • Driving a Honda CR-V which doesn't smell of pee
    • Honda CR-V
Re: Zafira Engine Vibration
« Reply #1 on: 09 July 2018, 21:20:49 »
How many miles has it done ?
Try cleaner but if that doesn't work it might be worth pulling the injectors and getting them ultrasonically cleaned and the pin re ground if you have anybody around there reasonable  :-\
« Reply #2 on: 09 July 2018, 21:21:10 »
The inserts won't help NVH any, and whilst they do reinforce the original mounts, if those are shot, then the inserts won't do much...
Renew the mounts and fit the inserts to these and report back.
« Reply #3 on: 09 July 2018, 21:23:03 »
Car is at 145000 now.
tigers_gonads
  • Kinston Upon Hull
    • Honda CR-V
« Reply #4 on: 09 July 2018, 21:26:11 »
Might be worth getting a price  :-\
My old man did a set on his old 1700 VX diesel Astra van with 155K on because it was running like a sack of shite.
Totally cured it  :y
« Reply #5 on: 10 July 2018, 07:58:46 »
Swap number 3 for the spare I gave you, you need to program the injector code in that is written on top of the injector.
A few things to note, if the copper sealing ring remains in the injector bore than a length of M8 (might be M10) rod screwed into it and pulled/tapped upwards will get it out, clean the bore well and seat well and fit with a new washer.
In theory you need to remove all three injectors to get number three out however, you can remove the fuel feed insert to the adjacent one which will allow removal (it obvious when you try).
Or shop around and fit a set of refurbed, most decent places do a good overhaul for about 40-50 per injector (I think I gave you two goosed ones and a refurbed one from memory so you should be able to get two done if needed)
« Reply #6 on: 10 July 2018, 14:00:15 »
Cheers. I’ll give it a go. Presume I need a new seal washer?
tigers_gonads
  • Kinston Upon Hull
    • Honda CR-V
« Reply #7 on: 10 July 2018, 14:22:53 »
I would  :y
« Reply #9 on: 10 July 2018, 14:54:08 »
Cheers. I’ll get some before I start. Presume they will be cheap enough to pick up locally
« Reply #10 on: 11 July 2018, 12:01:08 »
Any injector place or even a stealer, possibly a factors
« Reply #11 on: 11 July 2018, 12:19:39 »
Marks memory test....
You gave me 3 injectors...
2 in a Bosch box, 1 is loose, the other in a bag, with white paint on the end of the injector.
1 is in a bag on it own.
which do you recon is the best?
« Reply #12 on: 11 July 2018, 12:41:04 »
Ahhha, and helpfully I have an injector specialist about a mile away who have washers in stock
« Reply #13 on: 11 July 2018, 13:57:21 »
One is very clean and has part of the markings on the solenoid rubbed out (from memory), this is the recon one.
So the loose one in the bag with paint (I think)
« Reply #14 on: 11 July 2018, 14:00:21 »
Worth asking them about refurbing the other two?
Page created in 0.073 seconds with 21 queries.
