Pages: 1 ... 88 89 90 91 92 93 94 [95] 96 97 98 99 100 101 102 ... 1939   Go Down
Author Topic: So what have you done to your car today?  (Read 6917725 times)
0 Members and 29 Guests are viewing this topic.
paul.lovejoy
  • Ramsgate Kent
    • wife mad 2.6 cd estate
« Reply #1410 on: 10 December 2011, 16:33:36 »
ccccleaned and ppppolished the van ffffrather ccccold
« Reply #1411 on: 10 December 2011, 17:21:05 »
Fitted MID, mostly working, only got all the engine related wiring to plumb in... ::)
Should really wash it, but as above...
pscocoa
  • Sandhurst Berkshire
    • Volvo V90 D5 & Grandland
« Reply #1412 on: 10 December 2011, 17:56:23 »
cleared a P0420 fault with Maxscan - third time this year
« Reply #1413 on: 10 December 2011, 17:58:22 »
I feel you'll be buying a welder soon ;D
« Reply #1414 on: 10 December 2011, 18:06:08 »
Leave the welder where it is. I find the little orange lamp reassuring. When it goes out I shall know to check the bulb ::) :-X
Johnny English
  • Hungary
  • English antitalent
    • 1995. 2.5 V6 LPG manual
« Reply #1415 on: 10 December 2011, 18:11:55 »
Dismantled some unit of aircon at front of engine close to fan, service connector (fill up) was shoot out by overpressure. :(  Having found a used one I attempted to change them . Unsuccessfully. :( The ends of pipes are differents so I have to get it repaired by a welder who is able to weld alu aircon pipe as well. Not an easy job to find...I'm investigating away.  8) 8) 8)
Welder is found!  :y I had to do a little pre-work, I've cut down both of pipe end, fortune the outside diameter of one as the same as the inside diameter of other. So just cut a screw in and an other out and both of end could be fitted to each other.  :y I'm not sure in screws made by myself so I'm gonna get it welded properly. Welding tomorrow.  :)
I did this!
http://www.omegaowners.com/forum/index.php?topic=96819.0   :y :y :y
C20NE - X25XE
« Reply #1416 on: 10 December 2011, 18:46:48 »
 ;D ;D  felt the same last week , after many hours in cold for 2 days :y
MV6Matt
  • London
    • No car since 2022....
« Reply #1417 on: 10 December 2011, 20:50:14 »
Finally cleared the 'Coolant Level'  CHECK light - nothing to do with the sensor - bloody things plug had come out underneath. :-[
Might get the spare airbag out and swap it in if I'm not too careful................ ::)
(thanks Ian)
pscocoa
« Reply #1418 on: 11 December 2011, 15:08:38 »
But then what could I use my Maxscan for - it is the only code I get now - not complaining though :-X
« Reply #1419 on: 11 December 2011, 15:56:08 »
Upgraded her Rover 25 to have a pollen filter before the cold weather starts, so she has it ready for the spring.  Hoping it will fix the annual problem, whereby its the INSIDE of the screen covered in greasy, grimey....   ....SNOT!
What a sod of a job that is, as when we bought it (new), we didn't have the pollen filter option.  It took about 10mins, and cost £3.50 for genuine part ::).  The housing is all in place, all you have to do is fit a filter :y
Omega_Dan
« Reply #1420 on: 12 December 2011, 14:33:50 »
Changed oil + Filter and Spark plugs. Changed Washer Fluid. Replaced standard Headlight bulbs with orsam Night Breakers. Pete kindly gave me some wheel nut covers as i didnt have any. Cleaned them up and popped them on.
    • E250 Est / Elroq
« Reply #1421 on: 12 December 2011, 14:40:21 »
ive put the old prefacelift genuine gm exhaust onto my facelift.
Its a little shorter than I would like, but at least it isnt made of swiss cheese!
« Reply #1422 on: 12 December 2011, 17:10:09 »
Did a few routine checks on fluid levels, bulbs & wipers then took her for an MOT.
Passed with no advisories :)
« Reply #1423 on: 12 December 2011, 18:41:26 »
Shove a chav-me piece on it :y
« Reply #1424 on: 12 December 2011, 18:42:13 »
Closed the windows on TBE. Left the swimming pool in there...   :-[
Pages: 1 ... 88 89 90 91 92 93 94 [95] 96 97 98 99 100 101 102 ... 1939   Go Up
