Author Topic: Another problem :( has this happened to you?  (Read 3334 times)
51M0N
  • Hull
« on: 26 July 2011, 17:23:24 »
Basically it keeps cutting out when you come to a stop. Not all the time, it only happened 3 times last week but on the way home today 6 TIMES  >:( sometimes it acts as if it was about to cut out the battery light slightly illuminates then the revs will come back up, ive not lost any power or had any engine light. normally i would suspect idle valve but thats normally paired with erratic idling,
Crank sensor?  :o
Re: Another problem :( has this happened to you?
« Reply #1 on: 26 July 2011, 17:27:44 »
Wouldn`t hurt to paperclip it, 19 doesn`t always illuminate the EML. Erratic idling is normally airleak, cutting out tends to be IACV
51M0N
  • Hull
« Reply #2 on: 26 July 2011, 17:29:15 »
Its a bit iffy between 500rpm and 1200rpm. usually the revs would come down to 500rpm but sometimes it sticks above 1000rpm or just cuts out
    • E250 Est / Elroq
« Reply #3 on: 26 July 2011, 17:30:17 »
deffo time to paper clip test
and clean out your ICV
51M0N
  • Hull
« Reply #4 on: 26 July 2011, 17:31:58 »
Will do now.
Is carb cleaner ok? i tend not to touch these as it usually makes them worse.
« Reply #5 on: 26 July 2011, 17:31:59 »
Throttle flaps moving freely :question IACV seated in plenum securely :question
« Reply #6 on: 26 July 2011, 17:32:54 »
Will do now.
Just the job Si :y
51M0N
  • Hull
« Reply #7 on: 26 July 2011, 17:34:34 »
Back in 15  :)
Mr Gav
  • Leeds
    • Nissan 370z GT Edition
« Reply #8 on: 26 July 2011, 17:45:20 »
This was happening to me a while ago and it turned out to be the MAF sensor.
    • E250 Est / Elroq
« Reply #9 on: 26 July 2011, 17:45:25 »
sure we have a guide...
but remove, fill with carb cleaner and shake till clean
repeat as neccessary
drop of 3in1 oil on spindle.
dont poke a screwdriver or anything in cos youll scrape and damage it
51M0N
  • Hull
« Reply #10 on: 26 July 2011, 18:05:15 »
New one last week
51M0N
  • Hull
« Reply #11 on: 26 July 2011, 18:11:41 »
Right then!
Lifted the bonnet and noticed a mucky spray on the top rad hose, which I found odd as its always spotless.
I noticed the coolant level had dropped slightly,
I checked the oil cap........... it had some slight gunk/cream on it  :-?
Took the iacv off and cleaned it with carb cleaner and a soft thin brush
Fired it up and went for a spin, fine didnt cut out and revs always dropped to 500rpm
Then i did the paperclip test, now when i replaced the maf last week i had all the codes reset, the only code i got just now was a 31?   :o
« Last Edit: 26 July 2011, 18:17:31 by Simon131188 »
    • E250 Est / Elroq
« Reply #12 on: 26 July 2011, 18:13:11 »
31 normal if engine not running  :y
good result  :y
bit of oil cream  / mayo is normal, esp on short journeys / colder weather
« Last Edit: 26 July 2011, 18:13:52 by jimbob »
51M0N
  • Hull
« Reply #13 on: 26 July 2011, 18:13:50 »
good result  :y
Thought so, i was trying to find the guide lol, also checked all vacuum pipes etc... hmmmm
51M0N
  • Hull
« Reply #14 on: 26 July 2011, 21:13:56 »
been out for a 20mile or so drive and it was just lovely  ;D
think ive solved the water marks in that area. i went to check my tyre pressures and noticed my screenwash was empty...... filled it up and it came back out just as fast  :-[
