Author Topic: Repairing a Central Locking Motor  (Read 20657 times)
« on: 29 May 2010, 18:58:34 »
Central locking motor failures are a common and irritating problem. Whilst the motors are not too expensive on Trade Club  they aren't exactly cheap either.
The majority of failures are actually caused by the failure of a microswitch inside the motor assembly (it's actually a motor, not a solenoid), and this is cheap and relatively easy to change.
Firstly, the motor must be removed from the car by following the appropriate maintenance guides:
http://www.omegaowners.com/forum/index.php?topic=90504.0
http://www.omegaowners.com/forum/index.php?topic=90543.0
Once the motor is on the bench the black plastic cover needs to be removed, as follows:
Ease the rubber seal around the actuating lever off the motor body and lever.
Pull the actuating lever out to the fully extended position and remove the protruding part of the white plastic lever from the section that extends into the motor body by sliding it sideways.
Punch out the 2 roll pins by the lower end of the motor body and carefully prise the black cover past the four lugs surrounding the roll pin holes and off the motor body.
This is what you should see:
In the following picture you can see the silver motor in the centre with gearing to the left. To the right of the motor is the white microswitch that causes problems. Note that it may not always be white!
In the following picture the mechanism has been stripped down to show the two microswitches in position. Note that passenger and rear doors do not use the second (black in this case) microswitch, and it may not be fitted to the unit at all. The repair procedure is the same. however.
Here is the mechanism that was removed to show the microswitches. A rack is turned by the motor which winds a plastic sled up and down. This sled sits inside the internal part of the lock actuating lever.
Here is the assembly as it sits inside the motor:
The sled has 3 positions:
It can be wound fully down towards the bottom of the motor whereby it will take the actuating lever down with it and lock the door.
It can be wound fully upwards, taking the actuating lever with it, and unlocking the door.
It can be at a central "parked" position where manual control of the actuating lever is possible, allowing the door to be unlocked and locked manually. When the car is deadlocked, the sled is parked in the fully downwards position, which makes it impossible to manually lift the actuating lever to unlock the door.
It is the microswitch which senses the central position of the sled which causes problems. The purpose of this switch is to cut the supply to the motor as the sled reaches the central position from either above or below. As it wears the contacts become intermittent, and then fail completely, meaning that the supply to the motor is disconnected and the door does not respond to the central locking system.
The microswitch can be tested with a multimeter in-situ at this stage, or one or both of the switches can be replaced as a matter of course. If the rest of the device looks clean, there is no evidence of water ingress or other damage and the mechanism moves freely, it is a fair bet that a microswitch failure caused the problem.
So, on to repairing the motor. To achieve this, the microswitch needs to be removed. It must be desoldered from the connections that are moulded into the body of the motor. The body material has a low melting point, so care must be taken in desoldering to ensure it is not damaged. You will need a desoldering iron or a fairly fine tipped soldering iron and desoldering pump to achieve this.
Once all of the pins have had the solder removed and are free in their holes, ease the body of the microswitch out of the plastic retaining moulding.
The microswitch is a Cherry type DB2 with button actuator and straight PCB pins (not the solder bucket connections).
RS part number 290-0463, £1.26 at the time of writing looks a direct replacement, as does Farnell part number 1519007, £1.38.
Similar pattern switches are available from Rapid components (78-2410 @ 47p). Note, however, that these do not have the high 10A current rating of the original Cherry switch so might well have a shorter life in this application!
« Last Edit: 06 April 2012, 21:42:11 by Kevin Wood »
Re: Repairing a Central Locking Motor
« Reply #1 on: 29 May 2010, 19:15:16 »
Installation of the new switch is a reverse of the desoldering procedure, taking care that the switch is installed in the same orientation. A suitable adhesive may be required if the replacement switch does not have the 2 lugs either side that snap into the plastic body of the motor. Some switches just have mounting holes instead.
If the mechanism is particularly dry a small quantity of white grease or silicone or PTFE lubricant can be applied to the gears and sled mechanism. Bear in mind, though, that if lubricant gets into the motor or switches it will cause a failure, so, if in doubt, leave well alone.
Reinstall the black cover before testing as this locates the actuator correctly so that it will operate the switches. At this point the device can be connected to the car's wiring loom and tested to make sure all is well.
If the repair has been successful, tap in the roll pins, secure the extension to the actuator lever making sure the orientation is correct and fit the rubber cover where it protrudes from the casing, ensuring that a watertight seal is likely to be achieved.
Fit the motor back onto the lock assembly and reassemble into the door.
Note that the rear doors have a different motor to the front. On facelift models the part numbers are as follows:
Front 90 493 702
Rear 90 493 703
The rear motors are identical to the front apart from the following differences:
The plastic lever that connects under the rubber boot on the top is different
There is no second microswitch in the rear switches
Motor part number 90 493 702 can be fitted to the rear doors provided that the plastic lever is swapped over on fitting
Motor part number 90 493 703 can be fitted to the front passenger door, again, provided that the plastic lever is swapped over on fitting
Only motor part number 90 493 702 can be fitted to the driver's door, as the second microswitch is required in this location.
« Last Edit: 06 April 2012, 21:59:47 by Kevin Wood »
