Author Topic: mv6 3.2 engine code.  (Read 2693 times)
marrus69
  • bracknell
    • 52 mv6 3.2
« on: 12 November 2011, 19:04:06 »
so final got my car mv6 3.2 2002.done about 200 miles no faults can i just say this is an awsome car,so went and jet washed engine,dont no if its connected to my problem but thought i would say what happend.2 days later engine light came on, done brake and throttle thing.showing code 0150,it drives fine until you put your foot down then it flashes and only does 30mph what have i done,did i say how awsome this car is.
    • E250 Est / Elroq
Re: mv6 3.2 engine code.
« Reply #1 on: 12 November 2011, 19:14:16 »
That code relates to a lambda sensor...
P0150 O2 Sensor Circuit High Voltage (Bank 2 Sensor 1)
P0150 O2 Sensor Circuit Slow Response (Bank 2 Sensor 1)
P0150 O2 Sensor Circuit No Activity Detected (Bank 2 Sensor 1)
P0150 O2 sensor circuit malfunction (Bank 2 Sensor 1)
Wouldnt have thought that would limit you though...
What protection did you put in place before soaking all the engine?  (never a good idea)
    • E250 Est / Elroq
« Reply #2 on: 12 November 2011, 19:14:53 »
Where are you based?  may be someone local who can get some better diagnostic info out of it.
marrus69
  • bracknell
    • 52 mv6 3.2
« Reply #3 on: 12 November 2011, 20:28:15 »
no protection.im in bracknell will pm k.wood again thanks
Michael2.6
  • Bishop Auckland
    • Vauxhall Omega
« Reply #4 on: 12 November 2011, 21:57:09 »
I think your problem is in the power jetting your engine
water finds its way into your electric system
needs to be fully dried out
« Reply #5 on: 13 November 2011, 09:03:00 »
 :o :o
So an engine bay full of complicated electronics, relays ect. Sure, high pressure water sounds like a great idea!  ::)
Is P0150 your only code?
« Reply #6 on: 13 November 2011, 10:14:35 »
I would check the plug wells for water first. That would be more likely to cause a misfire code, so may not be the answer, but best to dry them out before the coil packs are wrecked.
« Reply #7 on: 13 November 2011, 10:16:50 »
Follow the lead back from passenger side 1st lamda (the one on the downpipe section), and check its plugged in, no water in connector, and wiring still in tack :y
As others have hinted, although perhaps not in a friendly way, jetwashing a modern engine isn't really a good idea - the pressure of the water with those things can force water past seals designed to keep delicate electronics dry.
