Author Topic: my 2.5 v6 cd auto estate  (Read 2861 times)
WINDOWMAN
  • dorset
« on: 16 November 2011, 07:09:26 »
i had noticed when braking hard my front wheels seem to lock up, seems more braking on front than back. does 2.5 v6 cd on 2000 x reg have abs. any advice... thanks
I_want_an_Omega
Re: my 2.5 v6 cd auto estate
« Reply #1 on: 16 November 2011, 07:14:52 »
ALL Omegas have ABS.
Do you not have an ABS light that comes on/off when you start up? If not then maybe a fuse has gone.
WINDOWMAN
  • dorset
« Reply #2 on: 16 November 2011, 07:17:57 »
i have checked.. silly me never noticed it..light comes on and off..
WINDOWMAN
  • dorset
« Reply #3 on: 16 November 2011, 13:24:10 »
can any one help with more infor.. abs light goes out etc when car started, but front wheels locking up when braking, which tells me abs not workin.. what do i need to check or change etc.. all help welcome thanks
I_want_an_Omega
« Reply #4 on: 16 November 2011, 13:38:03 »
mmmmmh.
I have experienced an engine tell tale light that was wired up with the ignition light to make it look as if the light was going off. The previous owner had actually modified the dash PCB. So, this could be done with the ABS light also. Check at startup and see is there is a difference between the ignition and ABS lights order. If there is a difference then it cant be rigged, but if they come on/off at the same time then it could be rigged.
If this is the case for you then the paperclip test should show that the ABS telltale light is open circuit.
I'd suggest a paperclip test and report back.
What age is your car?
Thanks - Rob
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
« Reply #5 on: 16 November 2011, 14:31:18 »
mmmmmh.
Thanks - Rob
you cannot paper clip the abs system :y
other rides
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
« Reply #6 on: 16 November 2011, 14:51:49 »
Is the load compensator valve free from rust and cr*p ?
iirc if its seized up, it would screw up the brake balance  :-\
I_want_an_Omega
« Reply #7 on: 16 November 2011, 16:08:18 »
mmmmmh.
Thanks - Rob
Sincere aplogies offered ......  :-[ :-[ :-[
WINDOWMAN
  • dorset
Re: my 2.5 v6 cd auto estate abs problem
« Reply #8 on: 17 November 2011, 06:48:35 »
paper clip never shows any faults, think..well thought i had sorted every fault on this car..where is and what does it look like ....the load compensator valve .. thanks so far for all the help..
WINDOWMAN
  • dorset
« Reply #9 on: 17 November 2011, 07:04:48 »
THE MODEL I HAVE IS 2000 ON X REG..
WINDOWMAN
  • dorset
« Reply #10 on: 18 November 2011, 16:39:26 »
is there a show you how guide to the abs on  here any where.. where things are etc and what to change .. could it just be a relay that needs changing./..?
