Pages: 1 2 3 [All]   Go Down
Author Topic: About NCDR and CID (both unpaired)  (Read 7147 times)
reinoso
  • Spain
« on: 17 July 2009, 20:41:41 »
Hello, I have already an NCDR and CID from astra G.
They are both unpaired, but I can't get paired them using "My Naff Code Reader".
when I connect the system, all works ok but the display shows DISPLAY SAFE and RADIO SAFE blinking.
Thanks
Re: About NCDR and CID (both unpaired)
« Reply #1 on: 17 July 2009, 20:45:39 »
"My Naff Code Reader" doesnt work very well for programming
TheBoy has tech2. (as do a few others here...)
providing "My Naff Code Reader" has buggered em permanently he may be able to sort you out  :y
where are you based?
  • Solihull
    • 530D M Sport, Elite 3.2
« Reply #2 on: 17 July 2009, 20:46:42 »
"My Naff Code Reader" makes a right hash of the pairing. Requires a genuine Tech II to do the job.
reinoso
  • Spain
« Reply #3 on: 17 July 2009, 20:51:56 »
In spain  ;D .. but my question is if this is normal, RADIO SAFE and DISPLAY SAFE blinking everytime? That means that both devices are unpaired? Thanks
« Reply #4 on: 17 July 2009, 20:55:38 »
Bugger, a bit far for any of the 'local' tech 2's then.
Im not sure if that is ready for pairing, or locked, one of the experts in em should be able to confirm
« Reply #5 on: 18 July 2009, 10:35:07 »
Both those messages implies that one is unpaired and the other is paired.
Stay away from any programming with "My Naff Code Reader", it makes a right hash of things. Its a good code reader, and ok-ish live data reader. Don't use for anything else.  Sounds like it may have already made a mess of this.  Remember the pairing code you attempted to pair it with - someone with a tech2 **may** be able to recover it.
If you don't have any joy out there, I **may** be able to get them unpaired/repaired, but postage may by high (www.royalmail.com would return postage)
reinoso
  • Spain
« Reply #6 on: 20 July 2009, 11:59:34 »
I know NCDR is unpaired, but I bought the CID and the guy said it was unpaired too!
I have another CID ... I thougth it was paired but i'm not sure ... when I connect this CID to unpaired NCDR, "RADIO SAFE" appears, blinking all the time, but never "display safe". Then .... this means I already had an unparied CID??? (I can't marry this old CID with "My Naff Code Reader")
Thanks for the answers !
« Reply #7 on: 20 July 2009, 15:15:34 »
Right, I cannot stress this enough, do NOT attempt NCDx/Display pairing with "My Naff Code Reader". "My Naff Code Reader" does and will make a mess of it, the likely outcome being that the components will be made a brick.
The combinations of Radio/Display safe are not always consistent.
Both Radio SAFE and Display SAFE alternating isn't usually good news, normally means both are paired, but not to each other.
Display SAFE normally means the display is not yet paired to radio, and also if neither is paired.
Radio SAFE normally means the display is paired, but stuck in an ID NOK Yet state.
Remember, all parts of the system - HU, CD Changer (even if part of the HU), Display and Telematics all have to be correctly configured and paired/depaired together.  I'll stress again, "My Naff Code Reader" CANNOT DO THIS PROPERLY
reinoso
  • Spain
« Reply #8 on: 20 July 2009, 16:38:43 »
Ok ... never try again with "My Naff Code Reader", will go to nearest Opel dealer ...
I discover there is a little microwire serial memory 93C56 instaled on CID. When I desolder it, and conect the whole system without the memory, the CID shows "DISPLAY program". I guess that this memory contains the "pairing" and the config (engine, wheels, CID language ...)
Maybe if I solder an empty 93c56, and take the CID to opel dealer, they could program and pair it to my unpaired NCDR...
« Reply #9 on: 20 July 2009, 16:41:56 »
Not sure you could use an empty one, but you are one the right lines  :-X
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #10 on: 20 July 2009, 18:21:24 »
Right area, but you need some data inside that chip
Radio & Decoding Technician
www.dndservices.co.uk
reinoso
  • Spain
« Reply #11 on: 20 July 2009, 18:58:42 »
ok ... I'm now comparing the content of the two CID memories, 2k to make some test.
Today I soldered the 93c56 of the CID KJ on the board of KH and the image appeared inverted ! strange ...
« Reply #12 on: 20 July 2009, 19:21:25 »
That might be a config issue, seem to remember that Astra ones and Omega ones are upside down to each other
reinoso
  • Spain
« Reply #13 on: 20 July 2009, 19:28:26 »
KH is vectra B, KJ astra G/omega, but I think all them are placed in the same way, with the three contacts upside... it is why I do not understand what's happening
« Last Edit: 20 July 2009, 19:29:08 by reinoso »
reinoso
  • Spain
« Reply #14 on: 21 July 2009, 15:15:49 »
Hello again, I have discovered memory locations to reset to get the CID unpaired. I have compared the content of unpaired CID memory and paired CID memory.
"My Naff Code Reader" says "theft protection: delivery state" on both CID  :)
I'm planning to go tomorrow to opel dealer and try to pair with TECH2.
Thanks
bigmac
  • Devon
« Reply #15 on: 24 July 2009, 16:41:05 »
Will look forward to any details on this as the CID might be the same as my vectra c one,i will know monday if its depaired or paired still as vauxhall are sticking tech2 on my CID quickly to tell me.
If its paired i will have to send it off for TB to work some magic  ;)
« Reply #16 on: 25 July 2009, 09:20:53 »
As said before, if its similar construction to Omega one (just with different interface board), should be able to depair easy enough.  I think Dave DND can do it as well, if thats closer/easier for you
bigmac
  • Devon
« Reply #17 on: 25 July 2009, 10:51:13 »
I did PM dave about a de-paired flash image some one said he had and if he knew how-to put this back into a de-paired state but he said he couldn't help me  :'(
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #18 on: 25 July 2009, 11:52:33 »
Unfortunately the memory dump I had has become corrupted.
« Reply #19 on: 25 July 2009, 12:02:08 »
Assuming (and I know that assumption is the mother of all mistakes) that its the same as the Omega flash, I may be able to furnish you with a dump ::).  Then I guess you need a guinea pig with a Vectra-C ;D
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #20 on: 26 July 2009, 09:22:15 »
A copy of the Omega dump would be appreciated, thats the one I have corrupted (been messing about with it, accidentally screwed up the master file)
bigmac
  • Devon
« Reply #21 on: 27 July 2009, 16:12:23 »
Well dealer plugged tech2 into car today and i put the new screen in and its id showed it was in delivery state so if anyone wants a flash off it and its easy enough for me to do i will have a go  :D
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #22 on: 27 July 2009, 16:31:10 »
PM sent   ;)
reinoso
  • Spain
« Reply #23 on: 27 July 2009, 16:32:56 »
do you need 93c56 dump of depaired KJ and/or KH ?
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #24 on: 27 July 2009, 17:02:40 »
PM Sent   ;)
bigmac
  • Devon
« Reply #25 on: 27 July 2009, 20:14:29 »
The one i have is a YF YG will let you know dave if its not sold by weekend i will arrange a meet in paignton  :y
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #26 on: 27 July 2009, 22:36:36 »
You local then?   :-?
bigmac
  • Devon
« Reply #27 on: 27 July 2009, 23:14:25 »
Yep  ;) Teignmouth  8-)
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #28 on: 27 July 2009, 23:43:19 »
Sounds like a drinking session is looming then . . . .
 :D
bigmac
  • Devon
« Reply #29 on: 27 July 2009, 23:46:56 »
If it wont take long to do what you need to do and you can guarantee me it wont screw it up  :-/ we could meet at your premises and have a wee look  :y or if you feel flush will sell it for a decent price  8-)
Tempesta48
« Reply #30 on: 07 August 2009, 23:09:48 »
Reinoso, do you know is the same could be done with a CID of an Opel Astra GTC?
I've got one with no more tries left to put the correct carpass and it's paired to a radio which doesn't exist anymore, so difficult to unpair :-?
Thanks in advance!
Pages: 1 2 3 [All]   Go Up
Page created in 0.034 seconds with 21 queries.
