Chat Area => General Car Chat => Topic started by: JamesV6CDX on 12 April 2012, 16:54:58
Title: Sodding Gearbox
Post by: JamesV6CDX on 12 April 2012, 16:54:58
Only last month did I fit a known good AR35 to my Omega
Last couple of days, it seems to give a good "thud" when applying some throttle from very low coasting speeds.
ATF level is fine.
Anyone got a match? Are these autoboxes made out of chocolate?  :(
No fault codes.
Maybe it's a sign that I should have chucked a manual box in there...
Title: Re: Sodding Gearbox
Post by: doz on 12 April 2012, 17:11:02
I have heard in the past the AR boxes don't like being left stood with no fluid in them. I wonder if this happened with the one you've fitted?
Post by: JamesV6CDX on 12 April 2012, 18:05:49
Maybe, though I would have thought unlikely. It drove us up to Amsterdam and back no problem, a couple of weeks ago!
Post by: TheBoy on 12 April 2012, 18:21:49
Do you have access to another 3.2 auto?
After Auto Addict's problems, wonder if its worth trying an ECU...
Post by: JamesV6CDX on 12 April 2012, 19:04:27
I read that - what was the history, what's the score with this?
No access to any other 3.2...
Post by: TheBoy on 12 April 2012, 19:06:39
Ask him, but my spare V6 TCM sorted his problem...
Post by: blackviper90210 on 12 April 2012, 19:06:54
Do the ECU's just unplug? ???
Post by: TheBoy on 12 April 2012, 19:08:08
yup
Post by: ngrainqey on 12 April 2012, 19:12:48
...if james needs an autobox ecu then mines spare  :y
Post by: blackviper90210 on 12 April 2012, 19:35:11
Can someone tell me where are the g/box ecu's situated please? :-[
Post by: JamesV6CDX on 12 April 2012, 19:37:37
Down by the drivers right foot, if I remember correctly :D
Post by: twiglet on 12 April 2012, 19:38:07
Right up behind the dash, driver's side, above the pedals.  :y
Post by: blackviper90210 on 12 April 2012, 19:38:47
Cheers James :y
If it's a simple job, do you want me to pop down and swop mine over and try it in yours? :)
Post by: twiglet on 12 April 2012, 19:39:01
That's the alarm/central locking ecu.  :y
Post by: blackviper90210 on 12 April 2012, 19:39:16
Cheers James, top man :y
Post by: JamesV6CDX on 12 April 2012, 19:43:00
Cheers James :y
Cheers mate, very kind offer, not sure a short drive will prove anything either way, though - it's only done it a couple of times...  :-\
Post by: TheBoy on 12 April 2012, 19:45:52
Cheers James :y
Swap for a month, see where fault goes.
AA said he noticed within a day
Post by: blackviper90210 on 12 April 2012, 19:49:19
Cheers James :y
Well we can swop ecu's for as long as you need to. Either until your car runs fine and or mine plays up, then you can tell me to sod off, it's your problem now ::) ;D ;D ;D ;D ;D
Post by: JamesV6CDX on 12 April 2012, 19:54:02
Cheers James :y
Cheers Dave - I'll give you a shout if I need to try that :y
Do you know what firmware yours is running?
Post by: Brikhead on 12 April 2012, 20:01:41
As said they are tucked up behind the dashboard above the fuse box, quite awkward to get to with the dash board in place I'd have thought.
Heres a picture so you know when you've found it...
(http://i383.photobucket.com/albums/oo273/brikheadphoto/Car%20sales/Om/autoecu.jpg)
Post by: blackviper90210 on 12 April 2012, 20:13:04
Cheers James :y
Come on James, I didn't even know where it was let alone what firmware it's got!!! ;D ;D ;D ;D ;D
How do I find out? ;)
Post by: Cliffo B on 12 April 2012, 20:43:22
Just a thought which atf did you fill up with?
Could be worth a try to drop both sumps
Check out the fluid condition
Could be some indication in the fluid
Then replace with new but which one?
Google Dexron V1 and in particular check out the technical write up on the GM product
It would seem GM developed Dexron V1
And other top brand names are on a follow on
I'm no expert but I can say that Miggy is running mostly on Dexron V1 content
I struggle to recognize a mechanical indication of a gear change
Just my thoughts on something to try
After all as already said it has been laid up for some time
Perhaps the fluid has become contaminated with the "running in process"
Post by: serek on 12 April 2012, 21:28:06
ATF level is fine.
No fault codes.
just go for manual box  :y
IHMO its waste time and money try get this auto box running  :-[
