Omega Help Area => Omega General Help => Topic started by: Elite_L0ver on 05 June 2012, 15:26:49
Title: Dash, ABS, TC Problems
Post by: Elite_L0ver on 05 June 2012, 15:26:49
hi all not bin on for a while as been busy with life  ;D :D
shot round the shop to get leccy i got back in the car and the abs an tc light on on the dash once i started it i drove down the road and the speedo stopped working revs were working petrol and temp guage were working but speedo stoped i pulled over turned engine off waited 5 mins started again still not working drove down the road the all of a sudden the lights went off and the dash speedo started working again HOW!!!!!!!
i have noticed the last week or so that abs/tc light come on for a short period then go off but just put it down to it being between 26-32c (reading from the car) i have also seen the airbag light come on but once i restarted car it went off (had to restart due to *automatc gearbox* on multidash) as u know i have gearbox issues lol just need the funds to do it
Sorry for the essay hope help is at hand!!!!! :y
Title: Re: Dash, ABS, TC Problems
Post by: tunnie on 05 June 2012, 15:29:13
ABS ECU is on the way out, its a pig to change on V6 too  :(
Post by: Elite_L0ver on 05 June 2012, 15:34:51
 >:( >:( NOT HAPPY.COM >:( >:( What bout the dash and tc
Post by: tunnie on 05 June 2012, 15:37:31
That is a symptom of the ABS ECU failing....
Post by: jonny2112 on 05 June 2012, 15:37:46
Expensive to replace, even second hand, provided you can get the correct match. Best bet is to get your own unit refurbed. Can't remember the recommended company's name off the top of my head though ...  :-\
It'll come back to me, but I'm sure you'll have had a load of responses before my brain gets into gear  :-[
Post by: Elite_L0ver on 05 June 2012, 15:42:05
as i said before >:( >:( NOT HAPPY.COM >:( >:(
so i have
1) a knackered gear box
2) abs ecu failing
3) iginition barrel sticky spring
4) no hot air in the car (just needs a clean out)
5) passanger window failing
and to top it off nearly totaled it on a rb today in the wet GREAT!!!!! :D :'( :-\
Post by: RobG on 05 June 2012, 15:44:07
http://www.ecutesting.com/?gclid=CJPRrNKqt7ACFQwjfAodPC9Y9g
http://www.bba-reman.com/uk/index.aspx
Post by: Terbs on 05 June 2012, 16:03:55
I hope this will not be an omen....but I bought an ABS ecu (secondhand) from someone on here for £35 ...had it programmed down from 3.0ltr to 2.5ltr....bargain :y
Post by: Elite_L0ver on 05 June 2012, 16:20:09
what u mean omen!  where's the ecu located  thanx for the links rob  how much it cost for the programming from 3ltr to 2.5
Post by: jonny2112 on 05 June 2012, 16:22:43
Cheers Rob, that's the one  :y
Post by: RobseyMV6 on 05 June 2012, 16:23:24
Need to check your codes on your unit, below pas bottle will be codes on it, might need to wipe the top off, you might not need to code if you buy the right one....
Post by: RobG on 05 June 2012, 16:24:01
http://www.omegaowners.com/forum/index.php?topic=90627.0
Get yours refurbed, around £120. Can still use car without ECU just wrap the pump in polythene bag
Post by: Andy H on 05 June 2012, 16:24:58
Read all about it in the maintenance guide Omega speedometer not working; ABS/ TC lights on. (http://www.omegaowners.com/forum/index.php?topic=90627.0)
Post by: Elite_L0ver on 05 June 2012, 16:43:36
thanx guys going to try the clean up first on the sensors on all four wheels first see what happens
Post by: Entwood on 05 June 2012, 16:59:11
Given your symptoms that has little chance of working ... :(
This is a known fault inside the ECU, the only remedy is repair or replace.
Repair by BBA-REMAN cost around £130 about 4 years ago, do a google for them then phone for latest price, service is fast and has (had) a 2 year warranty. No Tech2 or reprograming needed as the ECU is "yours"
Replacement needs either the same engine/transmision AND model year or it needs a tech2 session to programme to your car. New from Vx is basically silly money, a 2nd hand one may well be about to suffer the same internal failure  .... you take the chance I guess.
Work is fiddly not hard, access is the problem, empty the swearbox before you start !!!
Driving without the ECU gives certain problems ... no ABS, No Speedo, No power steering, and probably no insurance if they found out .... I only did 4 miles in mine without the ECU and said enough ...  the ECU was back within 5 days anyway.
Post by: Terbs on 05 June 2012, 17:01:18
Under steering pump filler :y
(http://i49.photobucket.com/albums/f272/Terbert/ECU1.jpg)
Post by: Elite_L0ver on 05 June 2012, 17:19:48
i wouldnt do this anyway iv got my kids in my car i cannot risk their lives ill give the cleanup a go and see what happens could it be where it has been really wet last 2 days
Post by: adey2 on 05 June 2012, 17:31:00
bba do it on ebay now and lot cheaper than using there website, 100quid with free posting where i used there website and cost me 130 with post,   here is link hope  helps    adey        http://www.ebay.co.uk/itm/390409146263?ru=http%3A%2F%2Fwww.ebay.co.uk%3A80%2Fsch%2Fi.html%3F_from%3DR40%26_trksid%3Dp4712.m570.l1313%26_nkw%3D390409146263%26_sacat%3DSee-All-Categories%26_fvi%3D1&_rdc=1
Post by: TheBoy on 05 June 2012, 17:43:12
If you are close to a tech2, might be worth a dabble first.  But I expect either no comms, or no faults found.
Post by: dbug on 05 June 2012, 18:24:18
Not entirely correct - gives reduced power assistance to steering - car almost undriveable with no power steering!  ABS & TC lights on gives no traction control and no abs - brakes otherwise will work as normal.  For no speedo use rev counter to assess speed (non working speedo is not an MOT failure!!)
I went the second hand route for the Elite Estate - got one off here for £45 same model/year/transmission - worked ok with no need for Tech2.  B*gger to fit due to space resrictions and only managed to refit 5/6 bolts.  Still going ok when car sold (4 years after fitting).  Also sold faulty one to a reconditioner on ebay for £50 + VAT!!
HTH ;)
Post by: Elite_L0ver on 05 June 2012, 19:29:50
HTH ;)
i know that thank you imgoing to put a wanted add up to see if i can get one
i thnk im going to when it stops raining and dries up
1 - clean sensor's on 4 wheels
2 - get a tech 2 on it
3 - if ALL ELSE FAILS find a second hand one hopefully same year trans etc and fit it
Post by: Elite_L0ver on 05 June 2012, 19:47:01
Just had a thought could having my spare wheel on cause any of this as it only started after i put it on
Post by: Andy H on 05 June 2012, 20:18:27
Bosch, in their infinite wisdom, decided to link the circuit board in the ECU to the multipin connector with a series of ultra fine wires and then cover them in glue. I haven't had one apart but I have read that some of the wires are gold and so thin that you need a microscope to see them and some are thicker aluminium.
The aluminium wires suffer from stress fractures and cause the failures.
Anyone carrying out the repair needs specialist skills to expose the broken wires without breaking any more, they then need to be able to bond the aluminium wires to the circuit board.
The cause of your problem is not a mystery and the repair is straightforward given the necessary skills and equipment.
Post by: Omegababe on 06 June 2012, 18:51:57
Thats what a woman would say, you make me look intelligent now lol
So glad there is people like you on this site
Post by: Elite_L0ver on 06 June 2012, 20:34:07
Who me lol
also would this abs and tc lights cause loss of power steering aswell i know what answer im hoping for :-[ :-X
Post by: Andy H on 06 June 2012, 20:38:55
Who me lol
also would this abs and tc lights cause loss of power steering as well i know what answer im hoping for :-[ :-X
Yes!  :y
Post by: Elite_L0ver on 06 June 2012, 23:13:55
Who me lol
Yes!  :y
BOL**X >:(
Post by: danzigfan on 07 June 2012, 08:00:50
I'm sorry for jumping in but I took this two videos in the morning today....cold start.
Are this symptoms the same? Cheers, Stan
http://s1103.photobucket.com/albums/g480/danzigfan1/?action=view&current=VIDEO0034.mp4
and this
http://s1103.photobucket.com/albums/g480/danzigfan1/?action=view&current=VIDEO0035.mp4
All the lights dimming a bit on one video
Post by: Elite_L0ver on 07 June 2012, 10:33:07
and this
no its not the same but on the vidio looks like you have either 1 of 3 problems
1) wire shorting out causing lights to dim
2) altanator on the way out
3) battery problems/charging problems
hope this helps and thankx for trying ;D
Post by: danzigfan on 07 June 2012, 11:01:59
Ah bugger... :-X
Post by: RobG on 07 June 2012, 11:05:40
Ah bugger... :-X
If you`ve got the SAI system active and it`s just on cold start only, pull the SAI fuse
Post by: danzigfan on 07 June 2012, 12:24:58
I don't know if it's active or not, sorry. Is it 29a fuse, 40A in the picture below?
(http://i1103.photobucket.com/albums/g480/danzigfan1/IMAG0338-1.jpg)
Modified: Secondary air pump is disconected
Post by: Andy H on 07 June 2012, 20:09:36
Who me lol
Yes!  :y
BOL**X >:(
Not the answer you were hoping for then................ ;D
Post by: Elite_L0ver on 07 June 2012, 20:21:56
Who me lol
Yes!  :y
BOL**X >:(
no it wasnt thanx
Post by: Omegababe on 07 June 2012, 20:33:11
Sorry but how does the ABS ECU failure cause the power steering to fail
Post by: Entwood on 07 June 2012, 20:37:11
Power steering on the Omega is electronically variable, and is adjusted with speed.... called "Servotronic" I believe. The speed signal comes via the ABS ECU, so failure of the ABS ECU results in the power steering defaulting to a very base setting .... this is very noticeable as the ECU fails because it is intermittent .. so the power steering assistance is also intermittent .. which I found very disconcerting !! Once the ABS ECU was removed then the system was stable but with very little assistance ... ie .. very heavy
HTH
Post by: TheBoy on 07 June 2012, 21:15:12
HTH
6cyl engines only. 4pots have bog std power steering
Post by: Entwood on 07 June 2012, 21:21:22
HTH
Thanks for that .. so 2/3rds of an engine gets 1/3rd of the toys .. :)  Serve 'em right for not buying a "proper" engined car .. :)
