Pages: 1 [2] 3  All   Go Down
Author Topic: Dash, ABS, TC Problems  (Read 9139 times)
Terbs
  • Brackley/Wareham
  • The Freezer Geezer
    • CD Saloon 2003
Re: Dash, ABS, TC Problems
« Reply #15 on: 05 June 2012, 17:01:18 »
Under steering pump filler :y
Elite_L0ver
  • Eastleigh, Hampshire
  • On too Omega #2
    • 99 2.5 V6, 03 2.2 CD FL
« Reply #16 on: 05 June 2012, 17:19:48 »
Read all about it in the maintenance guide Omega speedometer not working; ABS/ TC lights on.
thanx guys going to try the clean up first on the sensors on all four wheels first see what happens
Given your symptoms that has little chance of working ... :(
This is a known fault inside the ECU, the only remedy is repair or replace.
Repair by BBA-REMAN cost around £130 about 4 years ago, do a google for them then phone for latest price, service is fast and has (had) a 2 year warranty. No Tech2 or reprograming needed as the ECU is "yours"
Replacement needs either the same engine/transmision AND model year or it needs a tech2 session to programme to your car. New from Vx is basically silly money, a 2nd hand one may well be about to suffer the same internal failure  .... you take the chance I guess.
Work is fiddly not hard, access is the problem, empty the swearbox before you start !!!
Driving without the ECU gives certain problems ... no ABS, No Speedo, No power steering, and probably no insurance if they found out .... I only did 4 miles in mine without the ECU and said enough ...  the ECU was back within 5 days anyway.
i wouldnt do this anyway iv got my kids in my car i cannot risk their lives ill give the cleanup a go and see what happens could it be where it has been really wet last 2 days
Likes My Music LOUD!!!!
Elm327 code reader And OP COM available Locally PM Me
adey2
  • nuneaton, warwickshire
  • if all else fails hit it with a hammer
    • 2000 3.0 elite estate lpg
« Reply #17 on: 05 June 2012, 17:31:00 »
bba do it on ebay now and lot cheaper than using there website, 100quid with free posting where i used there website and cost me 130 with post,   here is link hope  helps    adey        http://www.ebay.co.uk/itm/390409146263?ru=http%3A%2F%2Fwww.ebay.co.uk%3A80%2Fsch%2Fi.html%3F_from%3DR40%26_trksid%3Dp4712.m570.l1313%26_nkw%3D390409146263%26_sacat%3DSee-All-Categories%26_fvi%3D1&_rdc=1
v6 locking kit , code reader available, engine hoist and engine stand
also has 2.6 mv6 estate 2001, hilux surf 3.0, vectra 2.0 lpg 2000
« Reply #18 on: 05 June 2012, 17:43:12 »
If you are close to a tech2, might be worth a dabble first.  But I expect either no comms, or no faults found.
« Reply #19 on: 05 June 2012, 18:24:18 »
Not entirely correct - gives reduced power assistance to steering - car almost undriveable with no power steering!  ABS & TC lights on gives no traction control and no abs - brakes otherwise will work as normal.  For no speedo use rev counter to assess speed (non working speedo is not an MOT failure!!)
I went the second hand route for the Elite Estate - got one off here for £45 same model/year/transmission - worked ok with no need for Tech2.  B*gger to fit due to space resrictions and only managed to refit 5/6 bolts.  Still going ok when car sold (4 years after fitting).  Also sold faulty one to a reconditioner on ebay for £50 + VAT!!
HTH ;)
Elite_L0ver
  • On too Omega #2
« Reply #20 on: 05 June 2012, 19:29:50 »
HTH ;)
i know that thank you imgoing to put a wanted add up to see if i can get one
i thnk im going to when it stops raining and dries up
1 - clean sensor's on 4 wheels
2 - get a tech 2 on it
3 - if ALL ELSE FAILS find a second hand one hopefully same year trans etc and fit it
Elite_L0ver
  • On too Omega #2
« Reply #21 on: 05 June 2012, 19:47:01 »
Just had a thought could having my spare wheel on cause any of this as it only started after i put it on
Andy H
  • Auckland
    • Mazda MPV
« Reply #22 on: 05 June 2012, 20:18:27 »
Bosch, in their infinite wisdom, decided to link the circuit board in the ECU to the multipin connector with a series of ultra fine wires and then cover them in glue. I haven't had one apart but I have read that some of the wires are gold and so thin that you need a microscope to see them and some are thicker aluminium.
The aluminium wires suffer from stress fractures and cause the failures.
Anyone carrying out the repair needs specialist skills to expose the broken wires without breaking any more, they then need to be able to bond the aluminium wires to the circuit board.
The cause of your problem is not a mystery and the repair is straightforward given the necessary skills and equipment.
Omegababe
  • FAREHAM
    • OMEGA 2.5 ELITE
« Reply #23 on: 06 June 2012, 18:51:57 »
Thats what a woman would say, you make me look intelligent now lol
So glad there is people like you on this site
Elite_L0ver
  • On too Omega #2
« Reply #24 on: 06 June 2012, 20:34:07 »
Who me lol
also would this abs and tc lights cause loss of power steering aswell i know what answer im hoping for :-[ :-X
Andy H
  • Auckland
    • Mazda MPV
« Reply #25 on: 06 June 2012, 20:38:55 »
Who me lol
also would this abs and tc lights cause loss of power steering as well i know what answer im hoping for :-[ :-X
Yes!  :y
Elite_L0ver
  • On too Omega #2
« Reply #26 on: 06 June 2012, 23:13:55 »
Who me lol
Yes!  :y
BOL**X >:(
danzigfan
  • Jesenice, Slovenia
    • Omega 2.5V6, 3.0V6
« Reply #27 on: 07 June 2012, 08:00:50 »
I'm sorry for jumping in but I took this two videos in the morning today....cold start.
Are this symptoms the same? Cheers, Stan
http://s1103.photobucket.com/albums/g480/danzigfan1/?action=view&current=VIDEO0034.mp4
and this
http://s1103.photobucket.com/albums/g480/danzigfan1/?action=view&current=VIDEO0035.mp4
All the lights dimming a bit on one video
« Last Edit: 07 June 2012, 08:10:03 by danzigfan »
Elite_L0ver
  • On too Omega #2
« Reply #28 on: 07 June 2012, 10:33:07 »
and this
no its not the same but on the vidio looks like you have either 1 of 3 problems
1) wire shorting out causing lights to dim
2) altanator on the way out
3) battery problems/charging problems
hope this helps and thankx for trying ;D
danzigfan
« Reply #29 on: 07 June 2012, 11:01:59 »
Ah bugger... :-X
Pages: 1 [2] 3  All   Go Up
Page created in 0.017 seconds with 15 queries.
