Chat Area => General Car Chat => Topic started by: Webby the Bear on 11 June 2013, 17:15:00
Hi guys, hope you're all good :)
Ok, here's the scenario.... i'm on a slight slope facing downwards. I am in 'D' with my foot on the brake pedal. I lift off the brake ever so slightly and the car creeps forward (gravity + the auto creep) and there's a real bad grinding from the brakes. once my foot's fully off the brakes obviously the noise stops.
is this normal? note, this is non-omega. in my omega this grinding doesn't happen at all (cos its awesome! :)).
i'm wondering if the brakes need lubricating? had the wheels off and nothing odd. discs have plenty of material as do the pads. brakes work absolutely fine and I don't believe there's any disc warping (as there's no vibration under any sort of braking).
Anyone experience this?
what foreign shit box is this on then??? ;D ;D ;D
The Ford Fusion mate ::) ;D
lol,have you put copper grease on the pads ;D ;D
nah, I aint touched the brakes as they were all done before I bought the car. is this grinding normal? I remember being in my mates car when his did it... but just wondering if its going to be a concern? :-\
its a ford can't expect anything good about them ;D ;D ;D
thanks for the helpful advice ralf :y ::) ;D
only joking try some copper grease on the pads . mostly does the trick mate :y :y
you reckon its a lack of lubrication? that's what I was thinking tbh :y :y :y cheers ralf
my mate had a focus .it done the same ,until he put copper grease on :y :y
legend, ill do just that - cheers mate :y :y :y
;D :-X ::)
Had me worried there when you said grease the brakes ;)
On the backs and edges of the pads, not the fronts ;) ;D ;D ;D ;D ;D ;D ;D
cheers guys. going to grease them up tomorrow..... they have this stupid retaining clip on...
http://www.google.co.uk/search?biw=1366&bih=622&tbm=isch&sa=1&q=images+ford+fiesta+brakes&oq=images+ford+fiesta+brakes&gs_l=img.3...50405.51717.0.51912.7.7.0.0.0.0.136.493.6j1.7.0...0.0...1c.1.16.img.P0qlG0QD8Tg#facrc=_&imgrc=Ufdo_0E0CplzpM%3A%3BdxrDbCqrG2SEuM%3Bhttp%253A%252F%252Fimg.photobucket.com%252Falbums%252Fv213%252FFMSRacing%252FIMAG0862.jpg%3Bhttp%253A%252F%252Fpassionford.com%252Fforum%252Fford-fiesta-st-and-mondeo-st-parts-for-sale%252F419960-fiesta-st-front-brakes-essex.html%3B798%3B478
Does this just pop off?
.... that wire type clip going round the caliper in the pic... :y
Yeah, just use a flat blade screwdriver to prise it off (it might end-up down the road though) and use some pliers to pry it back in place. :y
Cheers BM :y
Sorry one last question.... when I remove the two bolts so I can remove the caliper (7mm allen head I think) they come out and are like little shiny cylinders.... i'm presuming these are affectively the sliders and will need lubricating??
Cheers BM :y
No they don't need lubricating as they slide in rubber sleeves :y
only need to remove the 1 sliding bolt and then tilt the caliper away from the disc :y
cheers boys :-* :-* :-* :-*
