Trading Area => Car Parts, bits For Sale & Wanted => Topic started by: pirate on 24 June 2013, 20:28:53
Title: air con high press valve
Post by: pirate on 24 June 2013, 20:28:53
right folks,im in need of the pipe with the high pressure fill valve for my aircon,shes based on a 2.5 v6 elite  99 t reg ,enyone got a good one as mines not holding gas.? or is this best to get new. :y
Title: Re: air con high press valve
Post by: Jimbob on 24 June 2013, 20:33:57
the valve itself unscrews...and is about £3,  not long had one from Vauxhall
Post by: ted_one on 24 June 2013, 20:39:12
Yep,had one fitted about a year ago by a local a/c firm...bent me over for £96....you live and you learn ::)
Post by: Jimbob on 24 June 2013, 20:47:29
Ouch!  I paid for a regas, when it was discovered...
went back the next day where they regassed again attempting to fit he wrong part
went back a week ot 2 later (with correct part supplied by me) and they regassed and fitted it for nowt!
excellent service!
Post by: ted_one on 24 June 2013, 21:01:42
It's one of the penalties of living 'down sarf'....you get owt for nowt here ::)
Post by: Dazzler on 24 June 2013, 21:28:08
As above :y
Post by: pirate on 25 June 2013, 18:00:08
interesting i was told valve at rear of engine bay was replaceable but one at front was part of pipe but it looks like it comes off,will have a go at removeing it.
Post by: Dazzler on 25 June 2013, 18:49:22
It does come off, it is nut shaped at the bottom but an odd size if I recall :-\
Post by: biggriffin on 25 June 2013, 19:14:14
H.p.  valve is 13277003 £3.77 +vat on tc. :y
As just got one,am a bit scared to undo the old one as it seems FT and dont want to snap pipe
Post by: sjc on 26 June 2013, 13:08:06
I have 2 of those pipes complete with valves and surplus to requirements.  In fact, I have 2 whole AC systems going to land-fill shortly (once I weigh the box to see how much weight I've saved by not re-fitting it)
Post by: mantahatch on 28 June 2013, 11:22:16
From memory there are 3 different ones. One pre 99 one 99 and one post 99. I had this problem on mums old Omega and the 99 was a special for afew months only or so the dealer told me. still cheap though.
Post by: pirate on 29 June 2013, 10:50:15
got to my nearest vauxhall dealership in epsom allams.parts came over with valve insert ,wrong had a look under bonnet showed my print off of of parts and mines bloody different and he wasnt able to check what was in stock computers all down,so no further and cant regas system brillient ffs. >:(
Post by: pirate on 01 July 2013, 17:57:15
ok latest from vauxhall dealer er dont know sir can you get it off car,ffs,i just want to know if it defo unscrews as its about a 17 mm on base but it dont feel like it wants to come undone ???????
Post by: biggriffin on 01 July 2013, 19:31:44
Pirate try this part number
Post by: Andy B on 02 July 2013, 00:44:42
Yes ..... it does. Support the boss that's welded to the pipe with your 17mm spanner (so it doesn't shear  ;)) & unscrew the valve with a 15mm socket.
(http://i84.photobucket.com/albums/k17/Tiff4327/Omega/S73F1430.jpg) (http://s84.photobucket.com/user/Tiff4327/media/Omega/S73F1430.jpg.html)
Post by: pirate on 02 July 2013, 17:31:54
your a star cheers mate,may the gods be kind to you,see you out there dude :y
Post by: Andy B on 02 July 2013, 19:45:56
You're welcome. And a new valve comes complete with the green seal ....... you could order one like I did & have a spare  ::)  ::)  ::)
