Omega Help Area => Omega General Help => Topic started by: DaviesEB on 23 December 2013, 16:50:35
Hallo All,
Bought a 3.0 Engine V6 and using it on my 2.5 V6. I have made the switch but engine does not start.
Can anyone be of help please.
Darth need your assistance please.
Cheers
Bright
What car did the engine come from? Probably an immobiliser issue... :-\
Hallo All,
Cheers
Bright
Does the EML flash constantly and rapidly whilst you try and start it ?
Yes the Engine i bought was a 3.0 and mine was a 2.5 I am sure you are correct it has to do with the immobiliser.
What can you advice? I am in serach of Darth as i got the 3.0 from him
Cheers
Bright
you need the other "bits" to go with the engine, and change them to yours ... IIRC its the immobilisor ring around the ignition key, the chip in the ignition key, and the ECU ... someone who knows better will correct me I'm sure .. :)
Have you tried it with the 2.5 ecu :-\
Yes i am trying it with the 2.5V6 ECU. Do i have to change same. Darth told me it was just a plug and play thing.
Else can anyone be of help to get him linked up.
Bright
I will have to get back with the Mechanic and revert to you again. let me get some more info from him.
Cheers
Bright
Bright
If you're using your original key, then the 2.5 ECU should work :-\
Try this... http://www.omegaowners.com/forum/index.php?topic=90581.0 (http://www.omegaowners.com/forum/index.php?topic=90581.0)
And report back with the codes :y
Thanks will try the paperclip tst.
Cheers
Thanks
Bright
