Chat Area => General Car Chat => Topic started by: grahamp on 19 January 2014, 21:12:01
Title: fitting tow bar saloon facelift model
Post by: grahamp on 19 January 2014, 21:12:01
hi I need a towbar fitted looking at possibly doing it myself how easy are they to fit to the facelift model and reading some sites they say there is a plug in the boot for the electrics where can I get the fitting instructions from free and have I got to cut my bumper any help would be great live in Welwyn garden city had a couple of quotes and they come back approx. 250-300 quid
the car is the 2.2 16v 02 plate cd saloon
Title: Re: fitting tow bar saloon facelift model
Post by: Andy B on 19 January 2014, 23:08:57
Easy to fit. All the bolt mounting holes are pre dimpled in the boot. There is a pre-cut section at the lower edge of a mini facelift so you just have a small cut either side of a flap that folds up to clear the towbar ..... would the facelift be different?  :-\
All the electrics are indeed at a round socket in the boot behind the boot trim. Give the cost of a real GM towbar loom, you could just tap into the relevant wires of the car's loom.
If nobody has the colours to hand, I have them in the back of my Haynes ...... somewhere  ;)
Post by: Entwood on 19 January 2014, 23:22:46
For road lights only ... 12N (black) socket ... if you want the additional power for 12S (grey) socket, or the full 13 pin setup, additional wiring /relays WILL be required
It all depend what you are going to tow .. simple trailer .. 12N existing car wiring is ample ... caravan with fridge, battery charging and the new "Trailer control" - (electric braking to stop swaying) .. needs all the extra supplies .. which are NOT at the boot plug  :)
Post by: Andy B on 19 January 2014, 23:28:23
Thanks Nige ..... I forgot that bit.
Also the socket in the boot doesn't feed the brake lights directly. It's fed from up front (behind the glove box) via a relay base that can be fitted with a check control relay that extends the brake light check of the car to the trailer/caravan - a useful feature for any car that regularly tows.
Post by: Vamps on 20 January 2014, 00:37:33
Whats that then?..........
Post by: blackviper90210 on 20 January 2014, 08:58:19
I've got my mig booked in with Fast Fit Nationwide. They charge £85 +VAT. They done my 2 previous motors too, highly recommended. With the facelift mig, no cutting of the bumper required :y
Post by: Entwood on 20 January 2014, 09:03:57
Electronic detection of excessive "sway" causes momentary application of one of the trailer brakes to help control/eliminate the sway. Requires a dedicated power supply of a reasonable current .. not fitted to my present 'van so can't tell you exactly....
Friends who do have say its pretty good ... :-\ :-\
read all about it ..
http://www.al-koatc.co.uk/
Post by: Auto Addict on 21 January 2014, 06:46:42
Felt it operate a couple of times in a strong cross wind.
Post by: chrisgixer on 21 January 2014, 17:41:31
I'm jealous.
Post by: Martin_1962 on 21 January 2014, 21:06:59
I fitted one without removing bumper not easy but doable, I may have a towbar with 13pin electics available
Post by: chrisgixer on 22 January 2014, 13:46:03
I'm jealous.
Typical tinker ;D
Post by: Auto Addict on 22 January 2014, 19:15:56
I'm jealous.
Typical tinker ;D
Caravanning and Custard, two of the greatest things in life :y
