Omega Help Area => Omega General Help => Topic started by: bluebuss on 03 June 2014, 11:35:09
has anyone had any dealings with the rear/rear mounts on the subframe....
the pair close to the rear diff mounts....
finding new ones is a bit of a quest....
mine are all torn, including the front mounts (found and ordered)
the rear ones however..... any advice from the masses??
thanks in advance.... :)
http://www.partsbase.org/opel/omega-b-1994-2003-13-7-1-rear-axle-crossmember/#p-ope-402943
no 8 on the link above...
No longer available. I stripped all the rubber off mine and filled the void with a poly compound... takes some careful preparation to ensure that the central block is correctly positioned, but one of three options...
1. Do nothing.
2. Replace with good secondhand. (Good luck finding them)
3. Repair.
Use the search on here to see my posts about my repair :y I can't remember whether it was a separate thread or buried in the "What have you done to your car today..." one :-[
Was late November iirc :-\
thank you,
i take it these blocks dont ware out very often hence the lack of replacements.
one shop in the eastern europe area wanted 61€ a piece.. cant find the bloody address again.... >:(
Never let anyone jack on the dif on an omega. It will rip the rear mounts rubber apart.
Higher mileage ones become un bonded due to salt/general erosion of the aluminium. From what i've seen of these they will normally last 150k assuming no jacking if course.
No longer available from vx as Al says. So if your ever in a scrappy grab what you can. They are the same on all models.
Has anybody tried or approached power flex with the dimensions of said bush,or do pedders do an equivalent for say the early Holdens with a harrop diff., with a veiw to a group buy,as they are now an NLS item :)
Powerflex took measurements of the rear subframe front donut bushes before we did the group buy from Pedders.
Long before actually. The sales team decisded there where more lucrative...
Yes we did, no they didn't. Not likely too either.
Holden dif's are different with a direct mounting point. But it's not a mounting that is related to the dif.
It's the rear of the subframe, to the body floor. There are seperate cylindrical bushes that hold the dif to the subframe, these never fail, luckily.
So its a rear subframe mount to floor. Rather than a bush, as such. Although it is rubber bonded like most bushes.
These buggers. The ones that are undone to change the rear springs.
(http://i344.photobucket.com/albums/p326/chrisgixer/282C1D29-2D1C-4952-82FB-397B61A3601A_zpsus6mbhlw.jpg)
Harrop diff cover mounts use two bolts for each mount and the dimensions are different, sadly...
Too add, non Harrop monaros have a single centre mount ws the diff is bolted straight to the subframe unbushed. Again two vertical bolts at the rear mounting rather than one central bolt and two bushes :y
Not for the want of looking :y
Nearest I've found so far is.... Second pic down
http://www.benzworld.org/forums/w126-s-se-sec-sel-sd/1268836-rear-subframe-mounts.html
But again, no idea on scale/size in those pics. Plus looks like 4 bolt holes to the floor, but might be able to drill for a single bolt either side. :(
It's as much about the spacing where it bolts to the floor pan. In fact the subframe bolt position gives scope to raising/lowering the rear ride height...
Further googling shows its a single rear dif mount on the Mercs, where as the omega has two, so is roughly double the size and probably price of what we're looking for. :(
When i was doing my bros wheel bearing he got a old Daewoo matiz gear box mounts look identical. Never measured them though >:(
When searching Google images one or two results suggest that might be worth looking into.
But don't tell Esta, we'll never hear the last of it. ;D
Those look like a good replacement for Carlton/Senator diff mounts as they`ve been nls for a while now
This looks like it might fit if a little lightweight
CLICKY (http://www.ebay.com/itm/Engine-Mount-Mounting-Opel-Kadett-Vauxhall-Astra-Nova-FEM3020-/160968498728?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item257a785e28)
OR THIS (http://www.ebay.com/itm/Engine-Transmission-Gearbox-Mounting-Mount-Right-Opel-Vauxhall-FEM3363-/310586050686?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item48505f087e)
I`m gonna have a chat with one of the guys at autovaux and see if they have the later one in stock, If so I`ll take one of mine off and take it in for comparison and see where we go from there.
Any update on this? I'm also in need of these due to wear and tear (15 years / 180k)
Thanks
I'd like to know too. Had NO idea about these wearing and nls.... also had NO idea you're not supposed to jack them on the diff!! Can't remember if I have - perhaps just had an axle stand under there once or twice, but then again she's on 170k + so probably pretty stuffed through age, anyway.
I'm off to the scrappy!!!
Might be a case of mixing up some poly and moulding your own. As Al did.
Poly goop available on ebay. Apparently.
Will try and rustle up a linky thing... :y
I never followed up any alternatives as the Omega mounts are rebated to give a secure mount and none of the others have this and you would be solely relying on the bolt itself to resist any upward or downward forces.
One thing I`ve thought about though, you could swap out the whole rear subframe for a Senator/Carlton 24v subframe including the diff, This would need the single central mount to be fixed accurately to the chassis rail but wouldn`t be too much of a problem. Upside is nearly all 24v`s had LSD fitted, downside is standard diff mount is also NLS so you would ned to hope the one on page 1 would actually be a viable replacement.
Here do...
http://www.ebay.co.uk/itm/Fast-Cast-Polyurethane-Liquid-Plastic-Casting-Resin-Kit-1kg-960-ml-/281490331471?pt=UK_Crafts_DrawingSupplies_EH&var=&hash=item418a21974f :y
Nah. Ride height is set by the spring length, or rather via the spacing between the body and the trailing arm. Spring and pads.
The subframe can be dragging on the floor relatively speaking, via uj's in the drive shaft the subframe position can be where it wants, although the trailing arm pivot position will move. Which would need checking I guess.
If anyone is removing these from a car at the scrappies, make sure the diff or rear subframe doesn't fall on you during removal.
It will be pre loaded by the springs as well.
Oooh - good point! Thanks for the warning!
I see what you mean, but moving the rear of the subframe relative to the floor might allow some compensation for rear camber on lowered cars :-\
It's taken me all this time just to work out the ride height thing. You can imagine how how long the camber thing is going to take ;D
Should I get the Lego out again... ::)
In public? No! :)
