Chat Area => General Car Chat => Topic started by: Field Marshal Dr. Opti on 03 June 2015, 12:10:42
....the one I refer to as the fan belt but is actually called the auxiliary belt.
How often should this be changed?
I must confess I have not changed mine in 30,000 miles.
Easy job?
Expensive?
Right....I am going on the basis of watching TB do my 2.5....took about Half an hour or so. The belt cost £16 (Conti) and the old belt had been on three years, and was starting to degrade, although the mileage was about 15,000 miles maximum.
Best I can help you with :y
I should also say, that previous to this belt, had a tensioner melt and disintegrate. It was repaired at the roadside by the RAC. He charged me for a new belt.....however, I cannot say with hand on heart he actually fitted one. I never saw an old one !!!!!!!!!
So mileage could be higher as could be age :y
I just visually inspect it every so often, looking for cracks in the belt. 2.2's aux belt has done 59k I think
Perusing old invoices I can find no evidence that the belt has ever been replaced. :-\
Twelve years and 94,000 miles. :-\
It looks okay. That is all I can say.
They do 'look' ok, its when you look on the inside when its off the car you see how cracked they can be. :y
And, after my experience...I would be looking closely at the tensioner pulley.
Should be part of your on board spares kit, its normally the tensioner that goes.
Its a 10 min Job to fit, and only requires a spanner (15mm from memory), will cause all sorts of grief when they go and your stranded. ;)
(http://i251.photobucket.com/albums/gg299/zirk-photos/DSC03151.jpg)
Yep 15mm on the tensioner and is it E12/E14 that holds the tensioner onto the head?
Actually, change that to Tensioner Pulley. ;)
Would it be wise to invest in a belt AND a tensioner pulley? If it is an easy fix I'll have a bash at it myself.
Yep, just watch your fingers when you release the tensioner / spanner at the final stage. :y
What about the little torx bolt on the air-con bracket, I have always had to undo that too. On the 3.2 that is :y
I replace every time I do the cam belt, so every 4 years :y
Cant remember ever doing that one Joff, Ive always used the opposite force on the 15mm spanner to push the Tensioner in.
Having said that there do seem to be variations in belt sizes subject to manufacturer.
I do the same on the tensioner but this is on the other side so you can put the belt around the air con pump pulley :y
Hmm..., maybe Ive gone brain dead again, its that time of life you know. ;D
Tensioner pulley wheel bearings can be re greased if there is no play , 2 minute job :y
Tensioner pulley wheel[/u] bearings can be re greased if there is no play , 2 minute job :y
Which one is this?....Should I be able to move it against the tension of the belt?
I've counted six.
How often do VX suggest the auxiliary belt be changed?
Tensioner pulley wheel is top left as you look at engine from the front.On my 3.0l I also had to undo a small bolt on a pipe that runs across front of engine in order to get belt on.I think this is the one referred to in an earlier post?
Unlike the cambelt it looks as though Vauxhall has no specific time or mileage for the auxiliary belt.
What happens if it snaps whilst driving?
Thanks, Mr Baza. :y
I've put a 15 mm socket on it but will it move.... ::) ::)
If you are releasing the tension, put the spanner on the nut, and pressure clockwise iirc :y
My belt did not break...the pulley disintegrated !!!!! All that happened was dash lights all came on, and water started to overheat :(
Belt was just flopping about in the wind :y
I had the same thing happen about a year ago,although my belt got tangled and completely shredded itself, so the worst part of the job was removing all the bits of the old belt.
I was possibly lucky that it didn't break through the timing belt cover and cause mayhem in there ?
I had to get recovered home on the back of a truck for the first time in my life. :-[
If in doubt, I would recommend changing the belt and tensioner pulley. It doesn't cost much and takes around 15 minutes to do.
+1 :(
My pulley wheel shattered and played ping pong under the car , the belt made a right mess .
So where is the best place to get a belt (and just to be on the safe side) a pulley tensioner wheel from?
No Trade card/TC remember. :y
Well you know where i get both mine and it is my choice, egay and never had any issues in over 10 years since the first original one let go :-X
You can buy an equivalent Gates or Continental belt anywhere. The pulley will probably take a bit more tracking down, but any decent factor should be able to do it. It's usually the pulley that fails with these systems(whatever engine it's bolted to) and so aren't hard to find. A complete tensioner assembly isn't expensive, but normally unnecessary.
Ah...I see.
In my ignorance I imagined the pulley and tensioner to be one and the same. The same part.
My tensioner came with the pulley attached, from stock, as did the Conti belt, Euro Car Parts.
RAC man took the pulley off, gave me the rest of it, which is still in the garage, and fitted the pulley to the tensioner on the car. :y (Three years ago)
My experience does not allow me to say whether the pulley can be purchased separately, sorry Dr :(
Thanks, Mr Terbert. I'll see if they have what I need.
When mine went it was the tensioner pulley wheel that failed also and the belt just trashed itself.Got mine[don't recall what make]from A.E.Cook.Easy enough job to do,most awkward bit I found due to lack of space was the little bolt on the pipe bracket[aircon pipe?] that runs across front of engine in order to get new belt on.
From the pictures I've seen on Google it appears the pulley wheel and metal tensioner come as one item.....secured to the engine by a couple of small bolts or screws.
Cost around £30-£35
No nasty squeaks or grinding sounds from my car so I assume the pulley and tensioner are 'fit for purpose'.
Now I might be talking BS but I don't think renewing the tensioner/pulley is as essential as the cambelt tensioner. That is, obviously if there is no play, or rumbling etc,
As I said earlier, TB renewed my belt, tried the pulley/tensioner, and said all was ok in that department :y
I may just purchase the belt.....about £20, I believe.
Look at it this way...providing travelling no distance....you are renewing the belt anyway, so once off, you can determine the next course of action, and yes, that price should cover a conti/gates belt...as I said earlier, I paid £16, ordering online through ECP :y
Is this the johnny?......Before I order.
http://tinyurl.com/ngxo9ca (http://tinyurl.com/ngxo9ca)
Seems no schedule going by this
http://www.omegaowners.com/forum/index.php?topic=90441.0
So a visual inspection for cracks and splits presumably. As said.
94,000 miles and 12 years. It may be worth £14 for peace of mind.
SAI pipe assuming I've understood correctly :)
Nope, aircon pipe... At least it is on dbw v6s ;)
I change aux belts when they visually start to crack badly on the ribbed side (smooth side will always look good). I get my belts from wherever is convenient (usually GM, as they deliver it to my door, saves me going into Banbury). Also GM ones are always the right length, someof the Conti lookup tables are wrong, and provide a belt 10mm too short, straining tensioner.
I change tensioner pulley when its bearings sound rough (if you catch it quick enough, regreasing may be an option). I get my pulleys from GM. If your parts dept are shit, they will claim you have to buy whole tensioner, because EPC isn't that good.
Maybe I should go the genuine GM route then. I suppose they cost more than £14 though.
I can't find anywhere that sells the pulley separate from the tensioner.
Looks like a genuine GM belt is about £32.
Indeed. Much like the check step bush, epc only gives the entire mechanism, rather than the much cheaper part that's actually at fault. Like the pulley in this case.
Option, remind me, why aren't you on Tc? No dealer near?
Do we know a part number for aux tensioner pulley? Looked through the thread and can't see one unless I'm being blind of course ::)
Seems to came with the tensioner which you probably don't want, need, ......or can afford.
That should say Opti. Question for Opti....?
Egay is your friend , loads on there and more on the factor sites . Or stealers for a gold plated one ;D
Try here: [size=78%]http://www.vauxhall-car-parts.co.uk/acatalog/Omega_Drive_Belts.html (http://www.vauxhall-car-parts.co.uk/acatalog/Omega_Drive_Belts.html)[/size]
Scrolling down you will find the belt you need for £14, a complete tensioner assembly for £38.45(which is damn cheap if you ask me) and just the pulley for £8.40. Of course, you won't get bent over the counter at your local dealer if you buy these, but then you won't need any extra lube and be walking funny afterwards, either
Multi-rib belts are part of an industrial system, where you buy parts according to their dimensions rather than it being fitted to a SUHONKAWACEDES Thingy-Do-Dah. Buying them from a motor-factor is just getting someone else to match the dimensions with the manufacturer's part nos.
If you buy the SKF Aux kit you will get Aux belt tensioner, aux belt tensioner pulley, Water pump and aux belt in one box. I just get Daz to do both the SKF Cambelt and Auxbelt kits on my 2.6 every year (car does approx. 40K a year) and every four years on the 3.2 (Car won't have done 40K but the time period has been met).
I usually keep the belt I've removed in with the spare wheel along with the just removed pulley in the spare wheel well.
Just so people are aware....
I can't speak for those parts linked to, but I can speak from experience of the parts on this page
http://www.vauxhall-car-parts.co.uk/acatalog/VAUXHALL_STEERING_ARM_-_9195731N.html
From the same site. Some of the utter trash taken off people's cars on my drive way has come from there, with a life time of weeks not even months.
Not a single manufacturers name in site, on the pages I saw, although obviously I haven't looked at every page, I would ask people to consider what's being sold here if the manufacturer won't add their name to their own product.
Sorry Nick but I'm surprised tbh. But if you do KNOW those parts life span then fair enough.
Personally I'd much rather pay the £11 Tc pulley price.
more than happy to be guinea pig on the drive belt and pulley. Perhaps add results to your gen. dis. Thread re parts, Chris?
All genuine GM was the impression I was given.
Why though? It's for a Vauxhall. Nothing to say it's made by Vauxhall.
Plus there is no way on gods green earth that idler is GM Opti. ....seriously?
The parts on that site pre-fixed N are pattern, but cheap enough as nick says :y
The clue is the N at the end of the part number... It is shorthand for:
NEVER HAVING BEEN ANYWHERE NEAR A GENUINE VAUXHALL PART
It is in their small print... Also has the side effect of making their cheap fake parts actually seem quite expensive compared to genuine parts ::)
Called Vx this morning. They want £33-summat plus vat for just the pulley. ''What's that come to with TC discount, please''....''oh yes we'll get you a bit of a discount on that sir''.......................I didn't even bother getting a quote for the belt.
Luckily ive found a spare tensioner in the garage with pulley. ill regrease and pop that on.
simply put I refuse to pay that.
belt ordered from VCP. As said ill keep a note of how long it lasts and let you know, chris. if interested for your thread.
Actually, Mr The Bear, the belt wasn't so bad price. Mine was £26 with TC, which is about what I'd pay from a local motorfactors. Admittedly that's not as cheap as a cheap online supplier, but when I was asking about it, I had that many people on here saying they'd ordered the 'right' drive belts, they'd arrived wrong/too short etc, and ended up just going to Vx and getting the right one, saving the hassle, I opted for GM.
Vx dealer has just quoted £44 for the belt and £37 for the pulley (minus the tensioner)
Do Vauxhall have a price list or do they make it up as they go along?
Bend over M'lud! ;D
I did warn you!
3 to 4 times the price just for a Vx sticker on the packaging that you will put straight in the bin seems mental to me. And you have to choose your dealer carefully if you expect competence and good service as well.
Bend over M'lud! ;D
(http://www.katzy.dsl.pipex.com/Smileys/faint.gif)
What did you expect? If you're happy to pay the price, then do so... Otherwise shop around ::)
Yes, there are set prices for retail and trade (and tradeclub if a tradeclub item). Anyone should be able to get trade price on any item, unless you look stupid enough to pay full whack.
I did warn you!
I tend to agree.
It doesn't seem cost effective to spend silly money on an elderly dowager like the Omega.
I was expecting around £11 as that's what other people have paid previously according to the thread.
As I'm not happy with that I ordered from VCP. :y
And the trade club price is...? ::) ;D
