Omega Help Area => Omega General Help => Topic started by: EMD on 10 April 2016, 14:43:07
Title: Radiator ?
Post by: EMD on 10 April 2016, 14:43:07
Any recommended part supplier for a new engine rad please for a 2.6  :-\ Looks like the housing has cracked bottom offside corner . Been losing coolant gradually for a while now but noticed the puddle is getting bigger  :(
Title: Re: Radiator ?
Post by: 05omegav6 on 10 April 2016, 14:56:21
Ebay, £67 delivered :y
Post by: EMD on 10 April 2016, 14:57:17
Have you got the linky as dont want to order the wrong one  :)
Post by: 05omegav6 on 10 April 2016, 14:59:43
Ffs ::)
http://www.ebay.co.uk/itm/281089791116?_trksid=p2060353.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Post by: Steve B on 10 April 2016, 15:03:00
And can you pay for it and nip over and fit it  ;D ;D ;D ;D
Post by: 05omegav6 on 10 April 2016, 15:03:53
And you can sod off too ;D ;D ;D
Post by: EMD on 10 April 2016, 15:12:22
Thank you very muchie  :D Ordered  :P
Post by: EMD on 10 April 2016, 15:13:29
Free bacon sarnies if you do  :P :P :P
Post by: Steve B on 10 April 2016, 15:16:56
Good Luck  ;D ;D
http://www.omegaowners.com/forum/index.php?topic=129008.0
Post by: EMD on 10 April 2016, 15:19:12
Good Luck  ;D ;D
Thanks for the link  ::)  ;D
Post by: EMD on 12 April 2016, 22:43:37
Screw in thinymabob sensors that need transferring from the old rad to the new , do they need any kind of sealant on the thread and if so what sealant please  :-\
Post by: 05omegav6 on 12 April 2016, 22:52:20
None required...
That said, you might as well fit new whilst you can get at them :y
Post by: dbug on 13 April 2016, 01:19:18
I've always swapped existing sensors between radiators when I've fitted new rads - done a few now, and never any issues.
Personally I just re-use washer, but add a couple of turns of PTFE tape around the sensor threads.
HTH :y
Post by: EMD on 13 April 2016, 07:41:40
HTH :y
I was thinking that too  :y I know one of the sensors is the fan switch but what is the other one , or is there another one :-\ Been a while since i took one off .
Post by: 05omegav6 on 13 April 2016, 11:07:58
Other one is aircon/fan related :y
I only suggested new sensors due to ease of access, but if working well and not furred up then reuse away... if you were going belts and braces then you could also fit a new condensor, as changing that is basically a radiator out job ;)
Post by: dbug on 14 April 2016, 22:12:51
Then pay out to recharge aircon . . . . .   extra £160 for condensor + a/c recharge = 50% of the cost of the car!!
Why not just fix the item that is knackered - rather than replace other expensive items?  Rad out is not difficult or time consuming.
You know there's no F in Utopia  ;)
Post by: 05omegav6 on 14 April 2016, 22:41:10
Could just put radweld in it and call it a day with that logic... ::)
Post by: dbug on 14 April 2016, 23:11:05
No, why don't you read what people post?  I've highlighted it above - replace the item that is knackered, cost around £100 max incl. antifreeze, not add an additional £160 cost on parts that aren't causing issue.  Radweld is a crap product as we are all well aware on here!!
I've just bitten my tongue to prevent me being rude about your financial acumen!
