		Omega Help Area => Omega General Help => Topic started by: Simon72 on 01 October 2011, 21:59:43
				Thinking of up-grading brakes on the Omega..
 What do people think of these products and prices.. Or are there any suggestions from the members on here.
 Front Pads
 http://www.eurocarparts.com/ecp/c/Vauxhall_Omega_2.2_2003/p/performance-and-styling/performance-brakes/brakes2/performance-brake-pads/?1&pl5_115
 Rear pads
 http://www.eurocarparts.com/ecp/c/Vauxhall_Omega_2.2_2003/p/performance-and-styling/performance-brakes/brakes2/performance-brake-pads/?1&pl5_116
 Front Disks
 http://www.eurocarparts.com/ecp/c/Vauxhall_Omega_2.2_2003/p/performance-and-styling/performance-brakes/brakes2/performance-brake-discs/?1&pl5_117
 Advice welcome..
 Simon
				Just wondering what you think is wrong with Vauxhall's brakes? :)
				you'd be going some to overcook standard gm brakes on a 2.2 :o
 even in my 3.0l across Milton Keynes, I have to really try to get serious fade
				I am updating it for next years Rally for Heroes 3000 mile trip in 5 day.
 I will be going around Top Gear test track, Le Mans, Monaco, Hockenhiem, nurburgring.
 Also up and over the Alps on the Stevlio Pass
 So brakes will be used very hard and get quite hot.
				for track use, I would beef mine up :y
				although not sure about their ceramic percentage , ceramic brakes need to be very hot to work efficiently.. for normal driving (ie pads cold) in case of urgency, it wont brake the car like the standard pads..
				 ::)  must type faster.. :P
				yeah, even things like ebc redstuff catch me out - they cool on motorways, then don't work ;D
 So would you go for Green stuff then over Red?
 My own preference is for EBC 'Green Stuff' pads with Vx discs all-round  :y
 Generally, there's a good 'feel' to the pedal, and much less dust - and look at the terrain of The Valleys! ;)
				Or potentially consider OE pads (different from the aftermarket £15 ones you get from dealer). Not sure if man enough for track still....
				I'm having some kind of DejaVu here (must have said this to someone before) but .. do you have to use the Omega for some reason? Given the distances involved and amount of fuel you'll use dragging a weighty (underpowered if we're talking a 4cyl) between and around those places .. you might as well spend a grand on a cheap MX5; you'll have an awful lot more fun on track, won't need to bother upgrading the brakes and probably save money on the fuel...
 JMHO, but the Omega would be far from my first choice of car to take on track :)
 Why would I want to
 A) spend good money on another car when I already have a very good one that does 50 mpg
 B) not be able to get 4 people and luggage in the car with ease
 I will surely have some fun even in a car of it's size and show some of the sceptics that Omegas can do the same things that smaller faster motors can do ;-)
				EBC pads are a "marmite" choice. Some love them, some hate them.
 Despite their claim that they bite well from cold, I'd expect that they probably don't work as well as standard pads from cold. Not an issue for the track, or the alps, but might catch you out, as mentioned.
 I would have thought green stuff would get cooked on that sort of a trip. I have heard claims that they won't stand up to much hard driving in a Westfield / Caterham let alone an Omega with 4 people plus luggage. ;)
 For the price of those red stuff you could have 4 sets of standard pads. That's probably the way I'd go.
 As for the cross drilled, grooved disks, I wouldn't bother. It's cosmetic.
				If your getting 50mpg your stock brakes will be fine.
 But haven't ebc added another grade between green and red? Fast road use?  I wouldn't fit red pads for road use personally.
 They had Black->Green->Red->Yellow, now they've got Blue and Orange coming this month.. Orange is track only, Blue is 'track for road' apparently, tested to some EU regulation for brakes..
 Personally I've tried green (alright, better than it used to be but really no better than stock on the MR2) and yellow (prior to Orange & Blue, their 'track' pad) which has great bite from cold and no fade at all (though the MR2 is ~700Kg lighter than the Omega, that's a lot less inertia to stop).. Having tried green & yellow, I wouldn't even bother considering green or red anymore..
				I dont know anything better than good tires for braking.. a chain is as strong as its weakest part ..
 so I would invest good quality tires first :y
 Why would I want to
 so what model of omega gets 50 mpg?
 Why would I want to
 DTi  :y
 Yes they have (see posts above). Pagid (if you can find any for Omegas) or Ferodo I would recommend for the sort of driving you'll be doing. 8)
 Don't go anywhere near Green/Red stuff for an Omega. :'(
 Matthew
 Why would I want to
 Mine ;-) Omega 2.2dti 16v
 Mine at present doing town runs averages 41.6mpg and on a good motorway run gets average 49.6 - 51.7 mpg
 Matthew
 Whilst I'm sure Ferodo make some decent pads, the ones Hellfrauds sell are hopeless on an Omega (and far more expensive than the better TC pad)
				I've got plenty of experience on Omega brakes - and I used to be a brake designer, too......
 it's a "swings and roundabouts" thing really. There are pad meterials which are good at working from cold and those which are good at working from hot - there are no pads good at both.
 You need to have a think about what you really want as a priority.....
 something like yellowstuff will work on the track admirably, but they don't heat up well from cold - a factor which you need to bear in mind on motorways.
 a standard pad will work well from cold, but probably won't last a half lap of the 'ring.
 I personally don't rate Omega brakes at all - their heat-handling capability is very poor. Even in the 2.6 I can fade the pads every night on the way home from work. And don't even start me on vibrations. I guess it's the price to be paid for a design originating on 14" wheels.
 For your venture, I'd recommend yellowstuff, but bear this in mind on motorways.
 For my track-day cars that I MUST retain Omega brakes, I use yellowstuff and change them every day ( including discs )
 For the track car that I DRIVE,  I have a 350mm disc/caliper set that I swap round. Again with yellowstuff.
 on a slightly different front, brake pads are all very similar to one another. They all must pass the EU directive to be allowed on sale, so their quality is all the same. There is no such thing as a "bad" make of pads. The only thing that manufacturers are really able to do different in the heat range that they're effective in.
