Omega Help Area => Omega General Help => Topic started by: griffin on 15 October 2011, 14:46:38
Title: How do you remove a water pump
Post by: griffin on 15 October 2011, 14:46:38
Hi all
How do you remove a water pump I taken the aux belt off but cannot get access to the pump?
Do I need to remove plenum and camcover?
Thanks
Title: Re: How do you remove a water pump
Post by: TheBoy on 15 October 2011, 15:02:13
yup
Post by: griffin on 15 October 2011, 15:11:38
Bugger!
May be to much for me then!
Post by: griffin on 15 October 2011, 15:24:04
Ah sod it! in for a penny in for a pound I'm going to have a go now where are those distructions!!! :D
Post by: Varche on 15 October 2011, 15:26:50
Is a 2.6 different from a 2.5 then?
I changed mine on the 2.5 without removing the cambelt cover. You do have to be careful not to drop any of the three torx headed bolts that hold the pump in position but a bit of grease in the socket head helps.  :y
Post by: griffin on 15 October 2011, 15:28:16
Hi Varche
I've removed the pulley cover but the actual pump appears to be behind the cam cover?
Post by: griffin on 15 October 2011, 15:47:02
How do get to the small nut and bolt on the cam cover just behind the Aux pulley  :o  :o
Post by: Varche on 15 October 2011, 16:19:11
Hi
From memory there are three small bolts - about 10 mm normal head that hold the pulley on the water pump. When you take those off THEN you can see into the recesses of the cam cover and just get at the TorX bolts that actually hold the pump onto the engine block.. Slim extn bar helps
have you got a new pump to fit? Or are you just renewing the seal? If you have a pump you will see where the torx bolts are.
Anyone confirm that the 2.5 and the 2.6 are the same in this area pls?
Post by: TheBoy on 15 October 2011, 18:41:44
remove aux tensioner (2 E45 bolts)
Post by: Elite Pete on 16 October 2011, 12:02:49
You can remove the pump without taking the cambelt cover off but be careful not to drop the torx bolts into the cover
Post by: Darth Loo-knee on 16 October 2011, 12:04:49
Yes. 2.5 has a short plenum a 2.6 has a long plenum  :y
Post by: griffin on 16 October 2011, 14:32:16
Thanks for all the help guys.
Finally managed to remove cam cover and reveal the water pump! Me thinks I need a new tool kit as I cant seem to find a socet that will remove the pump bolts just keeps sliding round lol
So thats a job for another weekend.
Post by: albitz on 16 October 2011, 16:01:17
As said,they are torx type bolts,so you will need the correct size torx socket to remove them. ;)
Post by: Andy H on 16 October 2011, 19:25:01
You need a set of these http://www.draperproducts.co.uk/31379/Draper-31379-DRAPER-EXPERT-7-PIECE-SET-OF-DRAPER-TX-STAR-SOCKETS-ON-A-RAIL.html (http://www.draperproducts.co.uk/31379/Draper-31379-DRAPER-EXPERT-7-PIECE-SET-OF-DRAPER-TX-STAR-SOCKETS-ON-A-RAIL.html)
(http://www.draperproducts.co.uk/ProductImages/31379_BD7TXi.jpg)
Post by: griffin on 16 October 2011, 20:01:06
Thanks Andy H, I'll have to invest in a set! ;)
Post by: griffin on 22 October 2011, 15:11:43
Having invested in the right tools the old water pump has been removed!
It there any maintenance I should do before fitting the new pump?
Cheers
Post by: Elite Pete on 22 October 2011, 15:33:09
Just clean the mating surfaces and put a bit of grease on them ;)
Post by: polilara on 22 October 2011, 15:44:24
Did you remove the plenum ? I just realized that is was recommended.
Actually I never remove it when changing timing belt etc. I just remove the part
is it "Throttle Body"
Post by: griffin on 22 October 2011, 15:47:02
Hi
Thanks Elite Pete!
I did remove the plenum not sure I needed too tho! May have been able to do it with just the Throttle Body removed
Post by: griffin on 28 October 2011, 18:41:14
God I'm a crap machanic!!
I've removed and fitted the new water pump now I cant get the flipping timing belt cover back on. The bracket that holds the aux belt pulley is in the way and I cant force the cover down behind.
Any suggestions please!!!!!
Post by: Osprey on 28 October 2011, 19:05:07
Take the bracket off - two bolts round the corner IIRC, nose wet.   :y
Post by: griffin on 28 October 2011, 19:10:37
Thanks I'll have a look in the morning  :y
Post by: griffin on 28 October 2011, 21:49:19
Final piece of advice on this subject hopefully.
Need to replace the antifreeze which I can get from my local factors. Do I need to flush the system first?
Post by: Andy B on 28 October 2011, 22:29:23
You need to make sure you don't mix different types of anti-freeze in there ie long life pink with blue ethylene glycol, so if the new is the same as what was already in there, then no, you don't. But if they're different, yes you do!  :y :y :y
Post by: griffin on 29 October 2011, 11:56:57
Thanks Andy B for advice about antifreeze!!
I seem to remnoving a lot of bits at the moment trying to get this timing cover back on!!.
The auxilary bracket is this helpd on by the two largish torx bolts just on the corner of the engine block?????
Post by: joff on 29 October 2011, 12:12:35
Yup :y
Post by: griffin on 29 October 2011, 12:14:17
Thanks and this does need to be removed? or is there another way
Post by: joff on 29 October 2011, 12:34:47
Just undo the two bolts and it comes off, and don't put it back on until you have the cam belt cover back on. :y
Post by: griffin on 29 October 2011, 13:37:21
Cant belive it I think I've done it lol.
Just a flush out and refil with new coolant and jobs done  :y
Post by: Andy B on 29 October 2011, 14:17:47
There's a guide somewhere if you need it, but when you have flushed through & you just have fresh water in the system, drain off what you can - which is about half the capacity - slowly pour in as much of your 5 litres of antifreeze, start the engine & top up as the level goes down and 'burp' the large hoses. The stat will open & the level will go down a bit more, top up what you can. Keep an eye on the level over the next day or so & top up as required.  :y :y
Post by: griffin on 30 October 2011, 12:35:57
Morning!
Almost there new coolants in cars upto temperature fans started coolants at the max mark
BUT!
I have cold air blowing though the vents temp set to high on both sides!
Thanks
Post by: Andy B on 30 October 2011, 12:39:20
Air locked. Burp all the large hoses you can get to, but it should sort itself out by itself.  ;)
Post by: griffin on 30 October 2011, 12:43:11
Thank Andy B one more probably daft question should I be burping with the expansion cap on or off!!!!  :-\
Post by: tunnie on 30 October 2011, 12:44:56
I'd leave it off, keep an eye on it  :)
Post by: griffin on 30 October 2011, 12:53:51
I did that and I've just had a shower of coolant from the expansion tank what am I doing wrong!
 :o
Post by: tunnie on 30 October 2011, 12:59:55
Was the engine hot? Sorry should have warned you if it was hot to release cap, very, very slowly. Let it go cold, start it (with cap off) while burping it. As you do it, just keep an eye on the coolant bottle
Post by: griffin on 30 October 2011, 13:04:24
Bugger, Seem to have loast all my coolant from the tank does this mean I need to start again with flushing and refillig with new coolant  :'(
Post by: tunnie on 30 October 2011, 13:10:37
somethings a bit off if you lost everything from the coolant tank  :o
You loose a little bit if its hot & pressure is released, but not that much!
Let it all go cold, top it up, then start it with cap off, burp it & let it settle
Post by: griffin on 30 October 2011, 13:13:09
Tunnie, top up with water or coolant there's about and 1/2inch of coolant left on the tank!
Post by: albitz on 30 October 2011, 14:04:06
Top it up with coolant - then as Tunnie says,start it from cold with cap off.Burp the hoses until it gets hot.Hopefully that will sort it. :y
Post by: tunnie on 30 October 2011, 14:09:33
Yes, always coolant, summer you can get away with water, but with weather now, always coolant in a 50:50 mix  :y
Post by: Andy B on 30 October 2011, 14:29:11
ah! but can you? ::) As you know coolant isn't just anti-freeze, it's also a corrosion inhibitor which is especially needed in an engine with ally bits  ;) ;)  :y
Post by: Andy B on 30 October 2011, 14:31:22
 :o
You should always be very very careful removing the cap from a hot header tank/radiator. System is pressurised because the coolant has got hot & there's nowhere for the pressure to go - it's supposed to be like that (the cap has a relief valve in it)
