Omega Help Area => Omega General Help => Topic started by: ree on 23 November 2011, 13:38:59
Title: HEATED SEAT NOT WORKING
Post by: ree on 23 November 2011, 13:38:59
hi all ive a little prob ,the heated seat on the passenger side does not work would it be a fuse as seems to be all wired up underneath seat or is that its gone conpletly  :'(  thanks REE
Title: Re: HEATED SEAT NOT WORKING
Post by: Andy B on 23 November 2011, 14:31:25
Both front seats fed from the same fuse.
Suspect the element has failed, although you seem to be unlucky in that it's usually the driver's seat that fails.
Take it out & have a look. You may be lucky that the burnt bit is obvious & you might be able to cut it out & re-join the element. My fix has last 7 years so far ..............  :-X
Post by: ree on 23 November 2011, 14:36:53
hi thanks for the advice will get the seat out see properly whats happ, let you know how it goes thanks REE
Post by: I_want_an_Omega on 23 November 2011, 14:57:38
You do need to be aware that you may have to do significant seat stripping to get to the damaged bit.
What year Elite do you have, cloth/leather, what colour are the seats and do they have side airbags?
I visit Cambridge regularly and also have a stock of heated seat parts - but only for mini-facelift cars, so may be able to help out.
Good luck  :y
Post by: tommyboy1289 on 23 November 2011, 17:39:40
Good luck  :y
My drivers heated seat burns when turned on, only my left bum cheek though  ;D
Any ideas?
P.S Sorry to hijack the thread
Post by: dbug on 23 November 2011, 18:55:27
Good luck  :y
Any ideas?
Yep sit on your left bum cheek only  :) ;D ;D ;)
Post by: Tony H on 23 November 2011, 19:22:33
Good luck  :y
Any ideas?
 Shouldn't be sit on right bum cheek unless your a masacist ::) ;D ;D ;D
Post by: TheBoy on 23 November 2011, 19:24:16
Good luck  :y
Any ideas?
Dont worry, I suspect it will soon fail, then both cheeks will be like blocks of ice ;D
Post by: I_want_an_Omega on 23 November 2011, 20:59:02
Good luck  :y
Any ideas?
Yep, this will be on a turn in the element. The elements use many (i.e. 0ver 100) fine wires, some of these break which then cause a hotspot. The hotspot will cause more wires to fail and heat up more, and so on ...... As TB says it WILL fail and then go open circuit and not heat up at all.
HTH
Post by: albitz on 23 November 2011, 21:05:56
My passenger seat heater also doesnt work,which brings plenty of complaints from its regulat occupant. ::)
Post by: I_want_an_Omega on 23 November 2011, 21:18:48
Cant help I'm afraid. Dont have a working pass seat  :(
Post by: feeutfo on 24 November 2011, 17:06:43
IMO remove the seat back, locate the connector plugs to the individual pads. Bell those out with a meter, hopefully the back will have failed, as that's easiest ime. and might be possible to repair seat the in car, (although it's short work to remove the seat altogether if the base is fubar.)
Once diagnosed then see if you can remove the plastic head rest inserts and the lumber knob, if not give up as they have to come off to remove the cover. Then the rest is as the guide iirc. As Andy says, hopefully the scorch marks will be obvious to find the break in the element.
Or replace the seat altogether with known working one.
Post by: feeutfo on 24 November 2011, 17:08:45
Oh and obviously be bloody carefull with the side sir bag.
Post by: I_want_an_Omega on 24 November 2011, 18:24:46
I'm being dumb - I have a seat available, but its for a MFL not a FL which is what the OP has. Sorry to have confused things.
Post by: jonny2112 on 24 November 2011, 23:25:44
I haven't tried mine yet  :-X
Must do that tomorrow.
Post by: ree on 06 March 2012, 16:13:40
ok thanks for all advice decided it was all to much trouble and as its only the missus side decided to buy her a hot water bottle in-stead :D
