Omega Help Area => Omega General Help => Topic started by: batt21 on 25 February 2012, 21:46:08
Title: chipping/ remap
Post by: batt21 on 25 February 2012, 21:46:08
Hello. Been told the 2.6 is not chippable or remapable, is this true. All the others are2.2, diesel and 3.2 apparently. Not mechanical so need some advise. It is a 52 plate 2.6 mv6...thankyou
Title: Re: chipping/ remap
Post by: Omega_Dan on 25 February 2012, 21:53:25
My 2.5 is chipped so yes it can be done. Unless someone says otherwise :y.
Post by: batt21 on 25 February 2012, 21:56:41
Dan,,is it worth it?....
Post by: Omega_Dan on 25 February 2012, 21:59:09
Yes mate. Slightly better mpg when driven normally. Doesn't bog down off the line and much better past 4500 rpm.
Mine is an auto also. :)
Post by: batt21 on 25 February 2012, 22:05:26
Thankyou Dan...
Post by: tunnie on 25 February 2012, 22:17:15
Yours is 2.5, so yes can be chipped.
A 2.6 cannot be chipped, main upgrade would be some 3.2 cams which would add around 20bhp
Post by: Omega_Dan on 25 February 2012, 22:26:24
Why is that tunnie? What the difference between the two?
Post by: tunnie on 25 February 2012, 22:32:34
Nothing to actually chip in the 2.6, electronic remap only, no noticeable gains. Cam upgrade way to go!
Post by: Jimbob on 25 February 2012, 22:33:16
2.5 and 3.0's can have a socketed chip replaced.
2.6 and 3.2's cannot, need a remap instead.
Post by: Omega_Dan on 25 February 2012, 22:34:19
Cheers tunnie and Jimbob
Post by: zirk on 26 February 2012, 12:56:48
Chipping and Remaps effectively mean the same thing, the ECU's Memory Map is changed.
2.0, 2.5, 3.0 and 2.5TD's all use Eprom based Memory, meaning the Eprom needs to be physically removed from the ECU and replaced with another Eprom, often called a re Chip.
2.2, 2.6 and 3.2 use on board Flash Memory, meaning the Memory can be changed (Re Flashed) in-situ, without the need to remove anything from the ECU, often called a remap.
Both methods end up with the same result, the ECU's look up Memory has been changed (remapped).
Some Chipping Companies also refer to a Full Remap, which in theory should mean changing the Memory Map to suit the Engine's individual characteristics and modifications, rather than supplying
an off the shelf predefined Map.
