Omega Help Area => Omega General Help => Topic started by: Zippy2012 on 27 February 2012, 19:47:49
Title: Bushes omega estate
Post by: Zippy2012 on 27 February 2012, 19:47:49
Hi all,
im thinking of changing all the bushes on my 1999 mv6 estate ive been looking on ebay but theres so many diff types i can get powerflex front wishbone polybushes & front anti roll bar bushes but only 2 centers,
can anybody tell me how many bushes are on all the suspension components?? also inc the rear diff mountings??
there was an old thread on here about somone sorting a full kit front & rear but has anybody found one??  :-\
& how much am i looking at?? & where can i get them all from??? powerflex fronts for 4 bushes £69.00...
car is starting to feel a bit saggy & wonders a little now ive gone from the 225 60 15s to 245 40 17s as the old tyres took up most of the bumps on roads, my o/s front wishbone buggered so going to do both & do bushes same time  :y
Title: Re: Bushes omega estate
Post by: feeutfo on 27 February 2012, 21:36:15
Saggy up and down is predominantly worn suspension.
When the car starts deflecting round bumps and road imperfections, that's usually bushes PROVIDED tyres, pressures, and other components are up to scratch.
And that means no Falkens fitted ime.
I think you've seen the
Polly thread...? \/
Post by: Zippy2012 on 28 February 2012, 00:45:06
Polly thread...? \/
yep i noticed it just after io posted this! count me in for a rear set!!!
Post by: feeutfo on 28 February 2012, 00:50:08
Polly thread...? \/
Post by: Zippy2012 on 28 February 2012, 00:56:29
Polly thread...? \/
how many bushes or on the mig?? i maybe able 2 retro fit most of them from a 4x4 shop local who has a huge box full of poly bushes at 50p each! i can easy do the antiroll to wishbones with disco shock bushes as they are the same size looking at them earlyer the panhard rod bushes are neer identical to the wishbone bushes but have a better measure once i get another pair of wishbones, but how many on the rear?? any idea?? cheers chris  :y
Post by: feeutfo on 28 February 2012, 01:19:27
From the front back;
Anti roll bar x2   (polly available)
Front wishbone bush x2 (polly available)
Rearward wishbone bush x2 (possible future polly)
Top shock mounts x2 (polly proved unsuccessful on other models)
Rear donuts x2.  (possible future polly)
Rear trailing arm bushes x4. (probably next future polly)
Rear dif to subframe x2. These never fail, pig to replace apparently.
Rear arb bush x2
Rear drop link eyelets x4
Diff blocks, Subframe to chassis x2 (polly unlikely)
Rear top shock mounts (probably not worth bothering with)
Bottom shock eyelet (ditto)
Post by: Zippy2012 on 28 February 2012, 01:39:25
Rear arb bush x2
umm i get a load of cheep 50p proflex bushes & inner sleves & see what fits... if they do i will let you know...  :y
