Author Topic: Washer jet identification, which side is it!  (Read 1824 times)
Varche
  • middle of Andalucia
    • Golf Estate
« on: 27 February 2012, 22:52:00 »
I can't tell from my bag of bits which side washer jet has a nozzle missing.
I have the complete assembly . Looking down on it the pipe entry is below the body and the nozzles are facing upwards with the clip up  and nozzle assembly is angled away on left and nearer on right. Drivers side UK RHD car?
Can anyone help me please?  I should have labelled them as i took them off.
freecall666
  • looking over your shoulder
    • 2.0l sweat tank on wheels
Re: Washer jet identification, which side is it!
« Reply #1 on: 28 February 2012, 00:08:56 »
are you meaning the ones on the bottet?. if so they fit any side just reset the jets with a pin after.
Solar charger fitted.
If not Broke dont fix it..
« Reply #2 on: 28 February 2012, 01:54:07 »
Bonnet washer jets - different part numbers for drivers/passenger.
They do look same though  ???
Or do you mean HID washer jets - these are deffo handed  ;)
« Last Edit: 28 February 2012, 01:57:47 by dbug »
bootie
  • Enix, Almeria, Spain
« Reply #3 on: 28 February 2012, 13:43:54 »
Bonnet washer jets can be used either side, just depends on how much faffing about you want to do with pipe and connections, the heads are identical and as has been said, just adjust nozzles to suit.
Varche
    • Golf Estate
« Reply #4 on: 28 February 2012, 13:49:01 »
Sorry meant headlight washers
bootie
« Reply #5 on: 28 February 2012, 14:25:14 »
Well in that case....... I have no idea :D as mine are missing :'( (hint hint anyone) ;)
symes
  • oxford
    • R reg 940 volvo
« Reply #6 on: 28 February 2012, 17:19:37 »
looking directly at jet as your face is were headlight would be - water pipe faces right - leftside  if water pipe left -right side  :y hope this helps
Rods2
  • Sandhurst Berkshire
    • 1999 3.0 Elite Estate
« Reply #7 on: 29 February 2012, 00:41:23 »
This is a picture of the jet for the left hand (near side) headlamp washer jet, so I'm after the opposite to this.
Carfix
  • Malmesbury, Wiltshire
    • 1997 & 1998 Omega Elites
« Reply #8 on: 29 February 2012, 11:13:20 »
For reference the Vauxhall part numbers for the Headlamp Jets are:
Right Hand (RH): V0090509518
Left Hand (LH) :  V0090509516
RH/LH as looking from the front of the car.
If you take the jet off and look at the back you will find a RH or LH stamped into the plastic above the manufacture date. There is also a number which looks like a part nmber but it is not the same as the "official" Vauxhall part number?
