Author Topic: Engine Management Light 2.2l 16V  (Read 5243 times)
GT
  • Bedfordshire
    • Omega 2.2L 16V CDX
    • Team UK Advanced
« on: 01 March 2012, 15:44:14 »
Hi Guys,
Today as i was driving the the engine stated to feel a little lumpy and under powered, then moments later the EML iluminated, and the car lost a lot of power, she ticks over OK but struddles...
I have tried the pedal test but nothing happens to give me a code.
I have changed the plugs recently, could it be one of those do you think or something more serious.
Your thoughts would be helpful
Gary :'(
You Light um and I'll fight um!!
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
Re: Engine Management Light 2.2l 16V
« Reply #1 on: 01 March 2012, 15:58:00 »
Need to get the codes read, but if I would have to guess, Cam Sensor.
« Last Edit: 01 March 2012, 16:07:07 by zirk »
« Reply #2 on: 01 March 2012, 16:21:02 »
First check the plugs are torqued to the correct value: 25Nm (18.43ft/lbs) (216.28in/lbs), no oil in the plug wells, dis pack pushed fully home and tightened down and multiplug pushed on tightly. Then if still misbehaving, as said, codes need reading before thinking of replacing parts  :y
GT
  • Bedfordshire
    • Team UK Advanced
« Reply #3 on: 01 March 2012, 17:18:14 »
OK just poped over to a mate houde who as a code reader, it is reading code PO303 but cannot find it in the codes, it seems to not be firing on all pistons, and my mate thinks the 303 referes to the third pot, either a plug or coil pack.
Now i have changed the plug and there is no diffrence, does the forum think it could be the coil pack ?
GT
GT
  • Bedfordshire
    • Team UK Advanced
« Reply #4 on: 01 March 2012, 18:51:26 »
Just had the coil pack off, and the cam sensor off and reconnected it all up, and the engine is running a little bit better, but i was wondering, could it be that the coil pack as cooled down, a little and therefore is not breaking down too much, and thus allowing the engine to run a little smother, or am i talking a load of B@&$@£Ks  :-\
GT
symes
  • oxford
    • R reg 940 volvo
« Reply #5 on: 01 March 2012, 19:28:17 »
could it be blocked injectors? only a guess
flyer 0712
« Reply #6 on: 01 March 2012, 20:06:58 »
i had similar problem...changed camshaft sensor...ran better for a mile or so then it started all over again...it turned out to be the lambda  sensor  the 1st one on the front pipe nearest the engine......?????????
GT
  • Bedfordshire
    • Team UK Advanced
« Reply #7 on: 01 March 2012, 20:12:30 »
Symes, does my engine have injectors (2.2L 16v), if so where are they ?
Lambda Sensor, what is this and how many do they have installed ?
ndmv6
  • huddersfield
    • 2001 2.2 auto cd
« Reply #8 on: 01 March 2012, 20:17:58 »
code 0303 is cylinder 3 misfire...,could be a duff plug or failing coil pack...hth.. :)
symes
  • oxford
    • R reg 940 volvo
« Reply #9 on: 01 March 2012, 20:20:04 »
injectors are on inlet manifold and lambda sensor is like a large bolt sticking out of the side of exhaust with wires on it-hope that helps I mainly do v6 an v8 engines also check inside cap of plug lead-could be loose or corroded
GT
  • Bedfordshire
    • Team UK Advanced
« Reply #10 on: 01 March 2012, 20:40:40 »
Ok
I will take the coil pack off again tomorrow, i have already changed the plug for a new one, i will also check out the lambda sensor.
Come to think of it, the rubber is split on the boots that slip over the plugs, could these be at fault ?
if so any idea what the part number for these are..
SJKOO01
« Reply #11 on: 01 March 2012, 20:49:24 »
Ok
A split in the boots tells me that they've had it, as I suspect that they've gone brittle to, instead of being flexible.  If the boots are split the spark can ark onto the head.  Take off the plastic cover to get to the dispack, replug dispack plug back onto the pack, and in the dark start the engine and see if there is arking going on  ::)
You can get a kit from GM that has the boots and new springs for the dis/coilpack the number is 9195820 :y
Not sure of the price, but I think I paid around £13 at the time, so would expect with bit of a rise it'll be around £16-20 perhaps?
« Last Edit: 01 March 2012, 20:52:24 by GooseMan »
« Reply #12 on: 01 March 2012, 20:51:36 »
Ok
Come to think of it, the rubber is split on the boots that slip over the plugs, could these be at fault ?if so any idea what the part number for these are..
Yes, a split boot or one with a piece missing can cause the spark to find the easiest route i.e. the ally head and therefore give a weak or non existent spark at the plug electrode! Boots are available from your local Stealer:
Coil (DIS) Pack Rubber Boot Kit........:  "    "  9195820 (4 boots + 4 springs)
They may be available singly, i'm not sure though, you would need to ask the guy in the Parts Dept. Hth  :y
edit: Must type faster! ;D ;D ;D
« Last Edit: 01 March 2012, 20:53:25 by PhilRich »
SJKOO01
« Reply #13 on: 01 March 2012, 20:54:22 »
Ok
Sorry I trampled on your fingers Phil  ;D
Can only get boots in the kit, they don't sell separate  :y
« Last Edit: 01 March 2012, 20:56:16 by GooseMan »
GT
  • Bedfordshire
    • Team UK Advanced
« Reply #14 on: 01 March 2012, 21:02:43 »
i have just tried to find them on www.vauxhallpartsdirect.com but cannot locate them
