Author Topic: Omega/Carlton LSD  (Read 1789 times)
Becker
  • Baronscourt N.Ireland
    • 2.5 v6 cd Omega
Omega/Carlton LSD
« on: 01 March 2012, 23:16:24 »
Was just wondering if a carlton lsd can be fitted or built into an omega casing??
2woody
  • Northumberland
Re: Omega/Carlton LSD
« Reply #1 on: 02 March 2012, 08:36:01 »
yes it can, and its relatively easy - I normally keep the cwp already there and just swap over the crownwheel carrier with the LSD gubbins.
it's far from cheap tho. Retail, the parts alone will be the same cost as a complete good-condition Omega
kcl
  • Finland
    • Volvo V60 D4 -14
« Reply #2 on: 02 March 2012, 08:56:38 »
Carlton being Omega A in the continental Europe, right? Are other rear suspension parts interchangeable between omega and Carlton?
2woody
  • Northumberland
« Reply #3 on: 02 March 2012, 10:22:14 »
certain parts are interchangeable, provided the Omega A is of the right vintage.
trailing arms, driveshafts, brakes, camber-correction arms.
bootie
  • Enix, Almeria, Spain
« Reply #4 on: 02 March 2012, 11:40:33 »
CCA only on GSI 3000 and Diamond 24v Estate, not on any other models as far as I am aware.
Becker
    • 2.5 v6 cd Omega
« Reply #5 on: 02 March 2012, 18:49:13 »
thanks, lifted a complete diff unit last nite complete with driveshafts, wot would b the best oil to use??
2woody
  • Northumberland
« Reply #6 on: 04 March 2012, 09:39:46 »
must remove driveshafts to do the diff pinion check.
