Author Topic: Leaking pink stuff....  (Read 2048 times)
HockeyDave55
  • Milton Keynes
    • 2000my 3.0 police special
« on: 03 March 2012, 09:47:22 »
Hi folks,
A while ago I changed the coolant but now I have a small leak from the drain tap at the bottom of the rad... I don't just want to pull the plug out but, Is there a seal or O-ring in there that can be changed???  :-\
Re: Leaking pink stuff....
« Reply #1 on: 03 March 2012, 09:51:00 »
There are a pair of O rings in there. Not sure if they are available separately but I believe the complete plastic knob with seals is.
If they haven't been disturbed in a while they can disintegrate when the knob is turned.
Drop AndyC on here a line. I'm sure he'll be able to get hold of one if anyone can.
http://www.omegaowners.com/forum/index.php?action=profile;u=1488
HockeyDave55
  • Milton Keynes
« Reply #2 on: 03 March 2012, 10:48:54 »
Thanks Kevin.
« Reply #3 on: 03 March 2012, 19:29:25 »
Tends to be the washer not the "O" rings.
Drain plug is 52463060 and the washer is 52462868
« Reply #4 on: 03 March 2012, 20:54:09 »
The washer isn't there to seal, it's just to stop the red plug from vibrating loose. The O rings are for sealing.
Oh! ??? That's my picture!!!  ;) ;D ;D ;D
« Reply #5 on: 03 March 2012, 21:01:14 »
Agreed ^^ - thats not a sealing washer
HockeyDave55
  • Milton Keynes
« Reply #6 on: 03 March 2012, 22:37:25 »
Thanks for the help guys, I'll try to drop Andy a line. :-)
