Author Topic: New Suspension  (Read 3686 times)
P6UL K
  • Dartford, Kent
    • Vauxhall Omega 3.0 Elite
New Suspension
« on: 03 March 2012, 10:14:39 »
Morning all,
When i fit my new suspension what other componants are worth replacing at the same time?  Top mounts, any bushes etc...?
Re: New Suspension
« Reply #1 on: 03 March 2012, 10:16:21 »
Yep. All of that. :)
P6UL K
  • Dartford, Kent
Re: New Suspension
« Reply #2 on: 03 March 2012, 10:19:44 »
lol... Cheers Chris!  :D
So just top mounts then?  ;)
Re: New Suspension
« Reply #3 on: 03 March 2012, 10:30:15 »
Top mounts are a bugger because the suspension has to be completely dismantled to check them. Both the rubber lump and it's internal baring needs checking for pitted races. The ball bearings wear a dip in the races in the straight ahead position where they spend most of thier life with all the weight of the car on them.
Bushes. Well, need I go on? Polly fronts with a good genuine or Lemforder rearward bush at the front give best results. Rear donuts, might be worth hanging on for the result of the polly progect with these.
Re: New Suspension
« Reply #4 on: 03 March 2012, 11:53:39 »
In fact now is the time to check everything else.
Plus, I found the suspension can take a month or so to settle down to its eventual ride hight. So if you can, do the work on old tyres, let it settle for a month or two, then get it set up. This means being very carefully setting up the camber when re fitting, and measuring the original camber setting in order to replicate it after the work, hence the guide, if that helps?
If its set up immediately after new suspension is fitted. Those settings will only be correct for a month or two, as it will sag out if spec as the springs settle, and wear the tyres odly until re set up again.
P6UL K
  • Dartford, Kent
Re: New Suspension
« Reply #5 on: 03 March 2012, 15:40:22 »
Done all these when i bought the car off of Simon over a year and a half ago now i think Chris.....
So new top mounts are the order of the day then?  Are these the right ones??
No mounts on the rear or anything?  Bump stops?
Re: New Suspension
« Reply #6 on: 03 March 2012, 18:29:44 »
Seems correct, but personally, I've had nothing but agro from even the simplest of first line parts. Even filters. Given the work and cost involved is it worth skimping there? Febi at a minimum I'd say, if they do them of course.
 Rear top shock mount seem fairly bullet proof. GM shocks don't seem to come with new ones, though, where as b4 do. What do you have?
 Rear typically involves springs shocks and donuts.... the odd dif block to chassis failure, but theses are dead easy to swap out.
P6UL K
  • Dartford, Kent
Re: New Suspension
« Reply #7 on: 03 March 2012, 19:20:24 »
I've bought THIS kit Chris...
I'll be going to my local Vauxhall dealer to get any necessary top mounts, those ones on eBay were just for an example really.
I'm on your waiting list for the Powerflex bushes as i'd like to upgrade and replace as and when they become avaliable  :y
Re: New Suspension
« Reply #8 on: 04 March 2012, 00:31:10 »
Christallmighty. B12's? You don't mess about do you. ;D defo leave the first line crap alone then. :)
Might pay to compare prices between vx and allgermanparts for top mounts. Both made by Lemforder, fairly sure. Allgermanparts usually cheaper for the same part. "usually"
« Last Edit: 04 March 2012, 00:43:36 by chrisgixer »
Re: New Suspension
« Reply #9 on: 04 March 2012, 00:43:11 »
Given yours is estate, how does the weight limit match up for rear axle? 1290kg, is that a lot for a max weight limit? How much is that? I'm crap with weights.
Also given the range of shocks and springs vx have for various engines, I'm suprised they list the same parts for all engines from 2.0 up to 2.5TD...? :-\
 I might check that with them tbh.
fiend61
  • york
  • each to their own
    • 2.5cdx 3.0mv6 3.2vec c
Re: New Suspension
« Reply #10 on: 04 March 2012, 06:53:10 »
the b12's will give excellent handling and firm everything up along with the lowering BUT wont they give a very harsh/hard ride ??
P6UL K
  • Dartford, Kent
Re: New Suspension
« Reply #11 on: 04 March 2012, 10:25:20 »
Ha ha! The shocks aren't B12's Chris, the kit is just called B12...
Bilstein B12 Pro-Kit Suspension Kit - Lowered Ride Height, Fixed Damping
The Bilstein B12 Pro-Kit Suspension Kit is what you get when you combine industry leading dampers with the winning name in performance springs. It is the ideal suspension kit to fit-and-forget. The fixed rate legendary Bilstein dampers (B6 Sport or B8 Sprint depending on application) are matched to the winning performance of Eibach Pro-Kit springs, giving a kit that will transform the looks and handling of your car - giving less body roll and vastly improved dynamics. Simply put, a great handling car for fast road use, with a lowered stance.
The Eibach Pro-Kit springs lower the car approx 25-30mm, and the dampers are fixed rate. There's nothing to adjust, so you can fit and enjoy. No damping rates to adjust, no ride heights or corner weights to adjust - Eibach and Bilstein have done all the hard work so you don't have to.
The Bilstein B12 Pro-Kit is the perfect choice for those wanting the highest performance, mildly lowered suspension kit (25-30mm), without any hassle of adjustability. For a more aggressive lowered stance (45-50mm), choose the Bilstein B12 Sportline suspension kit.
I have a trade card for parts from Vauxhall so cost won't be too much of an issue, plus i want to get all four wheel bearings done at the same time.
But i will double check axle weights and the correct package with someone on the phone before i order, its a lot of money to get an order wrong because of a simple detail.
fiend61
  • york
  • each to their own
Re: New Suspension
« Reply #12 on: 04 March 2012, 11:41:32 »
what are the dampers then B8's ???
P6UL K
  • Dartford, Kent
Re: New Suspension
« Reply #13 on: 04 March 2012, 11:57:37 »
You don't miss a trick do you  :D ;D :D ;D
fiend61
  • york
  • each to their own
Re: New Suspension
« Reply #14 on: 04 March 2012, 14:49:00 »
im blind  8) 8)  ;D
