Author Topic: Caravan heater  (Read 2920 times)
alfie
  • Gwent
    • Mondeo Ghia estate tdci
Caravan heater
« on: 07 March 2012, 07:35:45 »
Hi all, Well alfies gremlins have struck again,after my first trip out this season I noticed that the heater control was a bit iffy,it seemed to travel a bit more than it should.
Anyhow checked it out this week,and sod it all,the gas control had dropped through the base plate.Now this base is steel EZ coated but is exposed to the weather/spray underneath the van,and it's going to cost quite a bit of the folding stuff/plastic to put right.I might like to add that this heater is not made in the UK,but in bloodly GERMANY (TRUMA) so much for the master race.
The van is 8 year old,and has been much looked after and serviced,the heater base plate is difficult to see,and thus has not been noticed that fractures had developed.
Tonka.
  • Lincoln, Lincolnshire
    • 2000 2.5 CDX
Re: Caravan heater
« Reply #1 on: 07 March 2012, 09:04:32 »
That's terribly bad luck Alfie  :(
Might a caravan breaker be able to help  :-\
The happiest people don't have the best of everything,
they just make the best of everything they have.
Re: Caravan heater
« Reply #2 on: 07 March 2012, 09:13:45 »
How complex is the plate, could be easy enough to make up a new one?
« Last Edit: 07 March 2012, 09:44:02 by Marks DTM Calib »
bored bigyin54
  • south wales
    • black beast
Re: Caravan heater
« Reply #3 on: 07 March 2012, 09:25:51 »
there is a caravan breaker up near big pit mining museum i have got the adress for it somewhere let me know if you want to go that way :y :y :y :y
Seth
  • South Wales Valleys
    • '99 2.5TD GLS Estate
Re: Caravan heater
« Reply #4 on: 07 March 2012, 10:13:14 »
These people per chance Rolf?: http://www.caravanbreakers.net/
Whatever, good luck Alfie! ;)
geoffr70
  • Sunderland
  • Boobies
    • F/L 3.0 Elite, 3.0 MV6
Re: Caravan heater
« Reply #5 on: 07 March 2012, 11:39:57 »
The same happened to mine, it's ancient but easy to fix. Disconnect gas cylinder, take cover off heater then you should see the screws holding it down. Undo them. Disconnect gas pipe fitting, you might also have to take plastic cowling off underneath where vent is. Lift heater out. Replace any corroded pipes underneath with copper in the usual way (usually steel hence the corrosion). You can rub down the base and put red oxide on. New thermo couplings only about £8 IIRC. I also replaced the seal for the baseplate to floor (double sided foam). Cheap and easy
TC and BnQ Trade holder.
alfie
  • Gwent
Re: Caravan heater
« Reply #6 on: 07 March 2012, 13:22:58 »
Thanks for all your input,have all ready sourcedthe base,£18 might need a new gas safety valve,£70. Not much room to swing a spanner in there,getting a lot of advice from a bloke on one of the caravanning forums,very very helpful,he reckons that the fractures between the punched out holes are caused by the caravan wheels not being balanced,quite possible that?.
                                                   Alfie,
Re: Caravan heater
« Reply #7 on: 07 March 2012, 14:16:08 »
Thanks for all your input,have all ready sourcedthe base,£18 might need a new gas  ...... by the caravan wheels not being balanced,quite possible that?.
                                                   Alfie,
Probably. Until I recently had my caravan wheels balanced, the front of the fire would almost always be off its mounts when we ariived at our destination. A local tyre place poo-poo'd the idea of balancing my wheels ...... ''it's only a caravan, why bother?'' .... but I told him to just humour me & do as he was asked  ;) The fire front is now always where it should be when get to where we're going.  :y :y :y
Auto Addict
  • North Birmingham
  • Back to Vx to keep TB happy
    • Astra K Elite ST
Re: Caravan heater
« Reply #8 on: 07 March 2012, 14:47:52 »
First thing I did when I bought my caravan was have the wheels balanced.
I like red cars
Seth
Re: Caravan heater
« Reply #9 on: 07 March 2012, 22:53:29 »
Flash git!
CaptainZok
  • Bolton
  • Victim of Cyberbullying.
    • 3.2 MV6 Estate
Re: Caravan heater
« Reply #10 on: 07 March 2012, 22:58:02 »
I'm sure TB could suggest a cracking caravan heating solution with a gallon of unleaded and a box of Swan Vestas. ;D
TuBy's new whipping boy.
alfie
  • Gwent
Re: Caravan heater
« Reply #11 on: 08 March 2012, 06:07:29 »
That was a long time coming,
Auto Addict
  • North Birmingham
    • Astra K Elite ST
Re: Caravan heater
« Reply #12 on: 08 March 2012, 06:11:24 »
Flash git!
Oi! Less of the flash :o
I like red cars
