Author Topic: Dragging a load of cans .  (Read 1650 times)
« on: 10 March 2012, 21:05:07 »
When driving i can hear a rattle coming from the rear brake area ...sounds like im dragging a load of rattle cans along the road  ::) any ideas what it might be . And when i brake from stopping slowly i can hear the rear brakes stick and ease off  :-\
Agemo
  • Cleethorpes
  • Insignia
Re: Dragging a load of cans .
« Reply #1 on: 10 March 2012, 21:34:43 »
Sounds like you have a spring snapped in your back brakes, need to strip them down & replace. Time for a good service then.
« Reply #2 on: 10 March 2012, 21:40:32 »
Yes thats my next job , ive done the front end . It does sound like something is rotating in the drum .
Agemo
  • Cleethorpes
  • Insignia
« Reply #3 on: 10 March 2012, 21:59:13 »
Yes, when the spring snaps, (or turns to dust) the shoe levers itself away from the backplate, and rubs on the inside of the drum, it makes a terrible noise.
« Reply #4 on: 10 March 2012, 22:09:15 »
And you run the risk of them seizing so make it a priority ;)
« Reply #5 on: 10 March 2012, 22:12:33 »
:o
Ok that sounds like the problem then , i will inspect tomorrow . Are the springs vauxhall only parts or can i get them in an aftermarket brake shoe pack ?
noel
  • frome somerset
  • i feel the need for speed
    • 02 omega 2.6 v6 cdx auto
« Reply #6 on: 10 March 2012, 22:12:45 »
as mentioned previously probably a broken spring ;)
« Last Edit: 10 March 2012, 22:21:56 by noel »
« Reply #7 on: 10 March 2012, 22:23:44 »
:o
Fairly sure you get them in an after market fitting kit :-\ :-\ You may be able to bend yours to a usable shape if desperate
« Reply #8 on: 10 March 2012, 22:28:08 »
Cheers , ill get the replacements first as ill not know if ill be able to put it all back together without them and what condition the shoes will be in if the spring has been rolling around inside causing damage  :o
