Author Topic: Engine racing  (Read 2795 times)
oslo
  • fareham hants, south coast
    • Omega V6 manual saloon
Engine racing
« on: 11 March 2012, 11:45:24 »
Hi, got an engine problem with my manual transmission Omega, symptoms are similar to when first starting the car on a cold morning except this is occurring when engine is hot (around 97.5 on my temp guage) after for instance coming off motorway.  When changing into neutral, engine revs don't drop ie engine is racing, then engine revs very slowly drops.  These symptoms persist while engine is hot.  This obviously means I have jerky gear changes (different biting point) and fuel consumption is affected
Have checked throttle cable and doesn't appear to be fouled.  Being in my fifties, in olden days I would have diagnosed carburetor needed cleaning but I'm not so familiar with fuel-injection.  Anyone have any ideas ??  Apart from this, engine performance good, no dash warning lights and fluid levels checked regularly
Re: Engine racing
« Reply #1 on: 11 March 2012, 12:12:31 »
Sticking butterflys on throttle bodies :-\
Re: Engine racing
« Reply #2 on: 11 March 2012, 12:12:47 »
Idle Control Valve would be my first point of call.... Give it a really good clean :y
Re: Engine racing
« Reply #3 on: 11 March 2012, 14:28:00 »
As he said ^^^^ clean ICV
oslo
Re: Engine racing
« Reply #4 on: 11 March 2012, 18:42:22 »
Cheers for replies - are butterflies and ICV connected or similar   ???  Don't have so much experience on modern engines  :y
doz
  • Southampton
  • LC,GSi Carlton,Omega Elite
Re: Engine racing
« Reply #5 on: 11 March 2012, 18:44:45 »
Have a good look around for any split hoses. It maybe suffering from a air leak
oslo
Re: Engine racing
« Reply #6 on: 11 March 2012, 19:11:11 »
Another one added to the post count eh ?? ;D
oslo
Re: Engine racing
« Reply #7 on: 11 March 2012, 19:17:25 »
I see this has come up before actually so will check vac hoses after giving ICV a good old clean  :y
  • Auckland
    • Mazda MPV
Re: Engine racing
« Reply #8 on: 11 March 2012, 19:32:14 »
I think your diagnosis is still valid (except that the component parts have been repackaged, renamed and are now dependent on electrickery for every action).
The engines used in the Omega are prone to blocked crankcase breathers. Usual symptoms are leaking cam cover gaskets but another symptom can be gummed up throttle butterflies and idle air control valves.
If the ICV is gummed up then clean the breathers too (correction, if you don't know when the breathers were cleaned then clean them regardless).
Have a read through the excellent maintenance guides Maintenance Guide Index
in particular this one V6 Cleaning the Crankcase Breathers
« Last Edit: 11 March 2012, 19:33:48 by Andy H »
Elite_L0ver
  • Eastleigh, Hampshire
  • On too Omega #2
    • 99 2.5 V6, 03 2.2 CD FL
Re: Engine racing
« Reply #9 on: 12 March 2012, 17:40:01 »
http://www.omegaowners.com/forum/index.php?topic=90653.0
As he said do this it will help clean butterfly's and breather system
Likes My Music LOUD!!!!
Elm327 code reader And OP COM available Locally PM Me
