Author Topic: Prop shaft  (Read 3367 times)
Prop shaft
« on: 11 March 2012, 18:59:07 »
Is the prop shaft hollow ? While investigating the annoying rattle i ruled out the rear brakes and handbrake as all that has been checked . But while turning the prop i can hear what i think is something rolling around inside the prop like a loose metal bit  :-\
Murph
  • Dartford, Kent
    • 2.5 Estate
Re: Prop shaft
« Reply #1 on: 11 March 2012, 19:01:40 »
Yep - it is hollow, but for the life of me I can't figure out how something could get in there!
Re: Prop shaft
« Reply #2 on: 11 March 2012, 19:05:06 »
Its definately inside , if its open ended i could drop the prop and empty it ?
doz
  • Southampton
  • LC,GSi Carlton,Omega Elite
Re: Prop shaft
« Reply #3 on: 11 March 2012, 19:30:58 »
Do Omega run the rubber donuts each end of the prop like the Carltons do?
freecall666
  • looking over your shoulder
    • 2.0l sweat tank on wheels
Re: Prop shaft
« Reply #4 on: 11 March 2012, 19:32:04 »
may be a bit of the weld has come off inside. or rust under the plate with number on it, its rivited on to the shaft.
« Last Edit: 11 March 2012, 19:34:04 by freecall666 »
Solar charger fitted.
If not Broke dont fix it..
Re: Prop shaft
« Reply #5 on: 11 March 2012, 19:36:44 »
It sounds like a ball bearing , a weld could possibly be it ...bloody annoying though when the windows down you can hear it rolling about
If i drop the prop can i see inside if its hollow or is it sealed up ?
STMO123
Re: Prop shaft
« Reply #6 on: 11 March 2012, 19:41:18 »
It has a spline on each end to connect to gearbox and diff. :)
Re: Prop shaft
« Reply #7 on: 11 March 2012, 19:42:47 »
Mmm ? I wont get it out then  >:(  Only thing to do is drill a hole in it .
doz
  • Southampton
Re: Prop shaft
« Reply #8 on: 11 March 2012, 19:45:04 »
You drill it your bugger up the balance.
  • Auckland
    • Mazda MPV
Re: Prop shaft
« Reply #9 on: 11 March 2012, 19:45:56 »
The prop shaft(s) are hollow (they ring like a bell if you tap them with a spanner).
The Omega has a two piece shaft with a sliding CV joint at the centre bearing. I can't really see how you would get something out without cutting the shafts TBH
Oops, just occured to me. CV joints have big ball bearings in them (at least they do until something goes wrong............... ::).)
Re: Prop shaft
« Reply #10 on: 11 March 2012, 19:53:29 »
It only makes the noise if i turn the prop , i have been under the car and pin pointed the noise and its inside the prop right at the back where the prop joins the diff  ;) One thing i could do is seperate the prop from the diff and see if it does it when disconnected .
Wont be drilling it then , for now ill drive with radio a bit louder and look out for a prop shaft . :y
markfree
Re: Prop shaft
« Reply #11 on: 11 March 2012, 19:58:09 »
According to haynes it's not too difficult to get the prop off - only a 3 spanner job  ::)  - I wouldnt drill it.
I have a prop shaft on my f/l v6 2.5 if you want it and if I can get the bugger off :y
Re: Prop shaft
« Reply #12 on: 11 March 2012, 20:01:35 »
Ok thanks MF , ill drop the prop and further investigate and let you know if ill be needing it . Just going to confirm its inside then ill PM you . Many thanks  ;)
Agemo
  • Cleethorpes
  • Insignia
Re: Prop shaft
« Reply #13 on: 11 March 2012, 20:49:09 »
Given the cost of a propshaft (from a breaker on here) I would be tempted to just replace it.   ::)
Re: Prop shaft
« Reply #14 on: 11 March 2012, 21:00:00 »
No it doesnt,now get back to general chat. :P ::)
