Author Topic: 3.2 codes  (Read 2291 times)
AndyD_1961
  • Willenhall West Midlands
    • 51 3.2 mv6 Estate
3.2 codes
« on: 12 March 2012, 15:43:51 »
Hi
Just put a code reader on my 3.2 MV6 cleared a load but three keep coming back
0230 fuel pump primary circuit high
0155 O2S21 heater circuit open
0155 O2S21 heater circuit malfunction
I assume the 0155 is a duff lambra sensor bank 2 sensor 1
but what could the cause of the 0230 be
Thanks
Re: 3.2 codes
« Reply #1 on: 13 March 2012, 10:42:17 »
that 0230 is a rare code, I'll have to look that up when I'm back in the land of civilisation, as I'm currently breathing soot in that hellhole known as London :(
The other is either the lamda or its wiring.
Re: 3.2 codes
« Reply #2 on: 13 March 2012, 12:41:06 »
Possible duff fuel pump relay iirc. :-\
Re: 3.2 codes
« Reply #3 on: 13 March 2012, 17:53:44 »
OK, was it a good code reader?  There are 3 0230 codes, and nasty code readers always pick the first option. Because they are nasty.
But, look, as Albs said, at Fuel Pump relay, and also check the socket, and the ECU plug and socket, for dampness ingress.
AndyD_1961
    • 51 3.2 mv6 Estate
Re: 3.2 codes
« Reply #4 on: 13 March 2012, 17:58:29 »
Hi
It was a snap on solus pro i borrowed from a mate it does alot more if you know how to use it but i only know how read the codes
Re: 3.2 codes
« Reply #5 on: 13 March 2012, 18:07:38 »
Hi
Is that the colour LCD one? I get a feeling they talk 'dangle berries', and pick top option for a code.
Either way, you have a plan of attack now :y
AndyD_1961
    • 51 3.2 mv6 Estate
Re: 3.2 codes
« Reply #6 on: 13 March 2012, 18:19:22 »
Yes It is colour lcd mates a big snap on fan he's in the trade and 90% of his tools are snap on he must have spent thousands.
Are all the fuel pump relays the same  ie could i try the one off my 2.2
Re: 3.2 codes
« Reply #7 on: 13 March 2012, 18:30:23 »
Check PN, and contact layout (numbers next to pins)
AndyD_1961
    • 51 3.2 mv6 Estate
Re: 3.2 codes
« Reply #8 on: 13 March 2012, 23:25:34 »
Ok will try that tomorrow
AndyD_1961
    • 51 3.2 mv6 Estate
Re: 3.2 codes
« Reply #9 on: 14 March 2012, 14:45:50 »
Had a look this morning only thing i can see is someone has spliced the thin black with green tracer wire from relay 10 to a thin black wire using a really thick wire with fuse holder and a blue fuse
Re: 3.2 codes
« Reply #10 on: 14 March 2012, 15:31:56 »
That will be your problem. That's the coil side of the fuel pump relay. No valid reason to connect anything to that.
Where does this wire go?
AndyD_1961
    • 51 3.2 mv6 Estate
Re: 3.2 codes
« Reply #11 on: 14 March 2012, 16:27:17 »
Just had another look the cut  black with green tracer wire from the relay has been spliced into a thin black wire that goes into the lower of the two ECU plugs.
I have also found the other end of the black green wire that also goes to the lower ECU plug but its now connected to nothing
