Author Topic: S/wheel removal  (Read 3750 times)
S/wheel removal
« on: 14 March 2012, 17:33:52 »
Hello , i need to take my steering wheel off and center it as its currently off center ..  Any advice as to what i should be disconnecting , worried about setting off the air bag for starters presuming that has to come off to gain access to the nut holding it on  :-\
tia :y
Re: S/wheel removal
« Reply #1 on: 14 March 2012, 17:39:33 »
tia :y
Why is it off centre is the first question ... it cannot get there on it's own .. something has made it go there ... and there are only 2 options ...
1) It has been previously moved to the wrong setting - for some stupid reason
2) It is in the right place and some other adjustments have made it appear "wrong"
If you have never moved it, and know of no reason why it was moved .. then get it to a proper wheel alignement place ... WIM comes to mind .. and have it set up properly.  make no mistake ... it needs a PROPER alignement .. not a pseudo "4 wheel alignement" ... which achieves the square root of ......     :(
Re: S/wheel removal
« Reply #2 on: 14 March 2012, 17:45:43 »
Fitted new droplinks and track rods a couple of days ago ...measured the track rods so they were spot on to the ones i took off , the steering wheel was off center slightly before i started . The car drives and steers spot on , just need the steering wheel re aligned .
There was excessive play in the old trackrods and droplinks and thats putting it lightly so im presuming fitting the new parts has set the steering wheel in its correct position , just needs centering .
WIM
Sorry whats WIM  :-\
« Last Edit: 14 March 2012, 17:57:34 by eatmydust »
GastronomicKleptomaniac
  • Teesside (the nice bit)
    • 3.2 plod, 2.6 MV6, etc
Re: S/wheel removal
« Reply #3 on: 14 March 2012, 18:06:31 »
WIM
Sorry whats WIM  :-\
Wheels In Motion. The only people I'd trust to do any alignment work on my Omega, despite the 400 mile round trip...
Re: S/wheel removal
« Reply #4 on: 14 March 2012, 18:56:36 »
The first thing to check, then is:
With the wheels pointing dead ahead, is the steering linkage (the one that dangles from the steering box) pointing straight downward/forward. If it isn't then you don't want to move the wheel - you need to get the track rods set to that the wheels are straight ahead when that is straight down.
The reason being that the steering box has a load of 'damping' built into it around that position which is there to stop the car 'wandering' when driving in a straight line - if you set it up otherwise you end up with a flighty floaty car.
If you check that and the linkage is pointing straight down when the wheels are straight ahead then yes, you'd need to move the wheel - because someone has previously done it to cover up a bad alignment.
If that makes sense :)
Re: S/wheel removal
« Reply #5 on: 14 March 2012, 19:01:15 »
WIM
Sorry whats WIM  :-\
Mate if you change steering components such as track rod ends you need your steering checking/realigning properly - just because you used a tape measure, bit of string, or counted the number of turns, doesn't guarantee nothng!!
Re: S/wheel removal
« Reply #6 on: 14 March 2012, 19:03:46 »
Perfect sense aaronjb  ;)  A quick check on that i will do  :y
WIM
Sorry whats WIM  :-\
Okeydokey  ;)
Re: S/wheel removal
« Reply #7 on: 14 March 2012, 20:17:43 »
Get the car set up correctly. Do not remove the steering wheel to achieve this or the steering box will be off centre. Splines are too course anyway.
See wheels in motion web site for full geo set up. But also see the guides and FAQ sections on fault finding first.
Dr_X
Re: S/wheel removal
« Reply #8 on: 14 March 2012, 20:27:13 »
Plus your airbag light will stay on and need to be turned off.......
Re: S/wheel removal
« Reply #9 on: 14 March 2012, 20:32:21 »
Why? :-\
 he's not removing the steering wheel now, but even if he was...
Re: S/wheel removal
« Reply #10 on: 14 March 2012, 20:35:31 »
Going to check the steering box alignment at the weekend  ;)
Dr_X
Re: S/wheel removal
« Reply #11 on: 14 March 2012, 20:55:11 »
Why? :-\
Dont you have to unplug the airbag when you take the wheel off??
Re: S/wheel removal
« Reply #12 on: 14 March 2012, 20:58:02 »
Why? :-\
You do, but you don't turn the ignition on with it unplugged.  :y
Dr_X
Re: S/wheel removal
« Reply #13 on: 14 March 2012, 21:01:21 »
Why? :-\
cool i'll remember that next time I take the steering wheel off.......
Re: S/wheel removal
« Reply #14 on: 14 March 2012, 21:12:44 »
... And when playing with air bags, the first thing you do is unplug the battery anyway.
