Author Topic: AR 25 Issues  (Read 3241 times)
amba
  • Medway towns
    • German V6
AR 25 Issues
« on: 17 March 2012, 08:34:47 »
Had the atf and filter screen replaced few months ago ..( I supplied the parts Titan 4000/filter/gaskets) and gears seemed to be nice and smooth again.
Last few weeks have had the box hanging onto 2nd when going up the gears and seems to take longer to change up than  I used to remember.My main concern is sometimes when going down the gears it hangs onto 3rd and then gives a firm jolt when dropping down to 2nd.I have had the "automatic gearbox warning" come up just the once when it went into limp mode but a restart got it back to normal.
Thinking the oil might be down a bit I checked the other day and probably managed to get in around 500ml before it started running out,but what did come out was a nasty brown,would have expected it to be nearer new as only some 3 months old or 7k..does it discolour that quickly ?
Anyway as atf is at correct level I am considering getting it checked by ATF Specialist to see if any fault codes etc are evident.I have read that the solenoids can play up and as this seems to be an issue arond 2nd and 3rd is it possible to just replace this solenoid as sure that would be the cheapest first step although would need another oil change at around £70 plus gaskets.
Re: AR 25 Issues
« Reply #1 on: 17 March 2012, 12:21:52 »
Yep. http://www.omegaowners.com/forum/YaBB.pl?num=1277492465/0
amba
  • Medway towns
    • German V6
Re: AR 25 Issues
« Reply #2 on: 17 March 2012, 15:49:25 »
So probably the course of action to take would be :
1 ).Drop sumps again and give a good clean , check for evidence of any bust up thrust washer..if found probably worth getting another box
if not then go on to 2
2 ) .Locate somebody who can supply the 3 solenoids from an AR25 ready to replace existing hopefully duff ones.Fit them and then fill up with new ATF and fingers crossed.If all ok then job done...if fault still there make decision on gearbox replacement.Only wasted cost then would be ATF and couple of solenoids.
Assume diagnosis from AT Specialists would be able to identify if these  solenoids are at fault ?
Re: AR 25 Issues
« Reply #3 on: 17 March 2012, 15:55:11 »
Thought it was the 2-3, 3-2 change you were having probs with :-\
amba
  • Medway towns
    • German V6
Re: AR 25 Issues
« Reply #4 on: 17 March 2012, 16:00:52 »
Does seem to be Rob  :-\
Wasn,t sure if all solenoids should be done at the same time or just the possible problem one .Are these all the same from AR25/35 then,as might get an idea of what costs are likely to be comimg my way so if I can get it diagnosed on Monday by an  AT Company  and it does point to 2-3 solenoid that is a job I can probably tackle with another aft change.
amba
  • Medway towns
    • German V6
Re: AR 25 Issues
« Reply #5 on: 17 March 2012, 16:03:21 »
Forget to mention it did loose all drive this morning.Came off motorway slip as had done around 40 miles at steady 70.Pulled up to junction and car reved but didn,t go anywhere for few seconds then picked up .
Re: AR 25 Issues
« Reply #6 on: 17 March 2012, 16:27:59 »
Yes. http://opeloem.com/vauxhall/omega_1994_2003/transmission/four_speed_automatic_transmission/valve_body.html
« Last Edit: 17 March 2012, 16:29:41 by RobG »
amba
  • Medway towns
    • German V6
Re: AR 25 Issues
« Reply #7 on: 17 March 2012, 16:42:52 »
Cheers for technical stuff Rob.
Just need to find price now and see where we go .. imagine second hand is safe option as can,t imagine they go that often ??
Re: AR 25 Issues
« Reply #8 on: 17 March 2012, 16:47:39 »
Give Jpat a ring 01934 852772, quoting this, Solenoid valve 2nd to 3rd part # 209 35 02
Re: AR 25 Issues
« Reply #9 on: 17 March 2012, 16:50:51 »
When you replace the gearbox oil the torque converter is still full of the old oil which mixes with the new
noel
  • frome somerset
  • i feel the need for speed
    • 02 omega 2.6 v6 cdx auto
Re: AR 25 Issues
« Reply #10 on: 17 March 2012, 18:19:13 »
i have an old ar25 box here complete (but torque converter failed on it) if you want it you can have it for free if you fancy a run to somerset. but be warned it weighs 80 kgs  :y
