Author Topic: nocking n\s front wheel  (Read 1804 times)
truckman
  • stevenage
    • vauxhall omega
« on: 17 March 2012, 17:06:32 »
hi.i have a knocking.on my n\s front wheel.what tests can i poss do.to find where its comming from.
Agemo
  • Cleethorpes
  • Insignia
Re: nocking n\s front wheel
« Reply #1 on: 17 March 2012, 17:20:20 »
Jack it up, test for play by twisting the wheel, 3 & 9 o' clock, then 6 & 12 o' clock. Could even be just loose wheel studs, or a wheel bearing. Caliper could be loose, just use common sense really.
« Reply #2 on: 17 March 2012, 17:55:25 »
Is the knock in time with wheel speed? Or suspension movement? Or steering movement? Other?
truckman
  • stevenage
    • vauxhall omega
« Reply #3 on: 17 March 2012, 18:49:28 »
intime with suspension movement.was thinking mayb balljoints\top bearing?
noel
  • frome somerset
  • i feel the need for speed
    • 02 omega 2.6 v6 cdx auto
« Reply #4 on: 17 March 2012, 19:03:25 »
front droplinks are worth checking for movement ;)
SteveAvfc.
    • Mv6 2.6 V6
« Reply #5 on: 17 March 2012, 19:13:25 »
[/quote
front droplinks are worth checking for movement  x2
« Reply #6 on: 17 March 2012, 19:56:00 »
Drop links are most common, but could be a number of things.
To test drop links, jack BOTH sides of the front of the car onto stands, then get under the front and trace the roll bar to its very end above the wishbone. Grab the roll bar as close the the end as possible by hand and pull up and down. If you can feel play there, replace the drop links. (dog bone shaped rods that connect the end of the roll bar to the shock body)
If no play is found, proceed to the FAQ section where you'll find a host of tests in the handling guide.
« Reply #7 on: 18 March 2012, 00:15:37 »
Lay money its breaked drop links - its sometimes difficult to diagnose failed drop links.  Replace as they are cheap and easy to fit ;)
« Reply #8 on: 18 March 2012, 00:28:45 »
But will be a complete waiste of time and money for the op of its not.
Check first IMO. Play is blatantly obvious with both wheels jacked. ;)
