Author Topic: FS - bits & pieces from my scrapped F/L 2000 2.5 cdx saloon  (Read 1353 times)
markfree
Well the Tank (as my wife called it) has finally gone to meet her maker (would that be Mr. Vauxhall,  Mr. Opel or maybe the General himself  ;D  ) anyway I managed to salvage a few  ::)  bits and pieces as follows :-
towbar & twin elecs + all nuts/bolts/brackets £60 delivered
front bumper with fogs, temp sensor, reinforcer and brackets £60 delivered
wiper motor, linkage, arm and blades £50 delivered
n/s xenon hid headlight £40 delivered
o/s xenon hid headlight £40 delivered
Both headlights £70 delivered
centre switches £7 each delivered
Brand new rear springs £50 delivered
Brand new rear subframe donut bushes £30 delivered
air box + filter £15 delivered
radiator (no leaks) £60 delivered
towing eye £7 delivered
maf £25 delivered
servo to plenum pipe £15 delivered
alternator £40 delivered
2 x air-con radiator fans £25 each delivered both £45 delivered
Top & bottom hoses and other hoses £15 delivered
cruise control unit £40 delivered
egr valve £25 delivered
Aux belt tensioner £25 delivered
plenum & icv £35 delivered
inlet manifold & fuel rail & injectors £40 delivered
pair of horns £20 delivered
2 x lambda oxy o2 sensors £20 each delivered both £35 delivered
bonnet alarm switch £15 delivered
HID switch £15 delivered
clocks (rev,speedo,temp) £35 delivered
dis pack £40 delivered
1 set 6 plug leads (5 never used 1 done 10k) £20 delivered
MID/MFD - multi info/function display £40 delivered
rear n/s tail lights outer & inner tail light £30 delivered
rear o/s tail lights outer & inner tail light £30 delivered
2 x bonnet struts £20 delivered
2 x boot struts £20 delivered
petrol fuel pump £40 delivered
2 x sunvisors with mirror and lights £20 both delivered
Haynes manual (1994 - 1999) £12 delivered
Omega owners manual and hardback cover £10 delivered
If your interested and want a pic of your desired part then PM with your email address and I'll send you pics.
These prices are not set-in-stone so PM with a reasonable price and I'll consider it.
pauls
  • By the sea minehead
    • Bmw x3
Re: FS - bits & pieces from my scrapped F/L 2000 2.5 cdx saloon
« Reply #1 on: 21 March 2012, 15:12:35 »
Hello mate do you know if the sub frame bushes will fit my estate. if so i will have them. i do you want paying
Page created in 0.008 seconds with 16 queries.
