Author Topic: had to happen tonight :(  (Read 1272 times)
martin42
« on: 20 March 2012, 21:56:46 »
driving back from the gf's in northampton,over took a lorry and engine went into limp mode,missing like hell,got her home into the garage,turned her of,fired up again and no miss fire,checked back box and the hair had blocked up exit pipe,so new back box need  >:(
would this cause the missfire as i was using kickdown just before this happened...
Re: had to happen tonight :(
« Reply #1 on: 20 March 2012, 22:01:55 »
Not a misfire, rather a lack of power
martin42
« Reply #2 on: 20 March 2012, 22:07:26 »
checked fault codes and said missfire on 4 and 6,but runs ok now,bloody cars,just dont need this at the moment  :(
« Reply #3 on: 20 March 2012, 22:11:10 »
Restricted flow of exhaust gas by the "horse hair" will cause a significant back pressure at the cylinders, so giving a mixture of fresh air + fuel as well as the "old" cylinder charge that is now "exhaust" gas.. containing little oxygen..... thus a marked reduction in power ... this would be worse under "kick down" as you are requesting maximum power ...
HTH  :)
martin42
« Reply #4 on: 20 March 2012, 22:12:28 »
it does,thanks guys,just need a rear box now  :D
Page created in 0.026 seconds with 16 queries.
