Author Topic: Battery flat, car locked, can't get in.  (Read 2652 times)
Tetleysmooth
  • Rainham, Essex
    • Omega 2.0 CD
« on: 21 March 2012, 02:53:31 »
This is for a work colleague.
A mate of mine at work has a very nice Omega, but recently bought himself a Pajero. He parked the Omega up and started using the 4x4. Now the Omega's battery's gone flat and he can't get into the car. He's tried with the key, but the key apparently turn only so far and won't unlock the doors. He said he doesn't want to go through the boot and start destroying the back seats etc.
Has anyone got any advice I can pass on, please?
Thanks in advance.
NILS DESPERANDUM ILLEGITIMI CARBORUNDUM
freecall666
  • looking over your shoulder
  • fun for all, get with the program
    • 2.0l sweat tank on wheels
Re: Battery flat, car locked, can't get in.
« Reply #1 on: 21 March 2012, 04:13:02 »
door key should work keep trying to turn key if its not been used alot before it will be dificult to move.
Solar charger fitted.
If not Broke dont fix it..
HockeyDave55
  • Milton Keynes
    • 2000my 3.0 police special
« Reply #2 on: 21 March 2012, 06:10:44 »
I did this too and found by accident that if you use the key in the door it comes to a stop, I'm sure I lifted the handle and turned the key a little harder and POP, it's open....
noel
  • frome somerset
  • i feel the need for speed
    • 02 omega 2.6 v6 cdx auto
« Reply #3 on: 21 March 2012, 07:01:46 »
X1 :y
oh well that's another day done
The Red Baron
  • burton on trent.staffs
    • 2000 chipped mv6 3.0l
« Reply #4 on: 21 March 2012, 09:25:36 »
had the same problem, but keys were different to the locks...heres a little trick if the car has a tow bar with twin electrics........on the caravan socket..pin 6 if i remember right(bottom one), 12v constant feed, back feed it with bat charger with earth on towbar for a min or two & unlock with fob. job done. thats if the constant feed fuse is in of course.  :y
jon.
Tetleysmooth
  • Rainham, Essex
    • Omega 2.0 CD
« Reply #5 on: 21 March 2012, 09:38:18 »
Thanks for the replies chaps, I'll pass that on.
Murph
  • Dartford, Kent
    • 2.5 Estate
« Reply #6 on: 21 March 2012, 11:28:40 »
I did it a different way...
The key would not work in the door, but did open the boot, so I removed the boot light and hooked up some jumpo leads to the wires.
That let me operate the central locking.
The Red Baron
« Reply #7 on: 21 March 2012, 11:40:10 »
where theres a will, theres a way. :y
« Reply #8 on: 21 March 2012, 11:44:40 »
There's also the positive feed to the starter or alternator (which are certainly man enough to take the feed) and are the only 2 routes I would recommend for safety reasons (although the others will probably be fine ;))
They key in the door should work though, but ISTR that the button doesn't always pop up :-\
Tetleysmooth
  • Rainham, Essex
    • Omega 2.0 CD
« Reply #9 on: 28 March 2012, 06:48:33 »
Update!! I have one happy mate at work.
He tried this method and his car unlocked. He reckons he ran down the road whooping, silly bugger.
Day, he says he owes you a pint or three mate.
Murph
  • Dartford, Kent
    • 2.5 Estate
« Reply #10 on: 28 March 2012, 10:21:53 »
Just glad to help Dave - at least he got in.
