Author Topic: hello All i have question about omega A 2.0 GL 1987  (Read 6758 times)
omegaly
  • libya
« on: 21 March 2012, 14:05:00 »
i tired look for diagnosis port for opel omega A 2.0 GL 1987
i search under hand break and near by fuse box
so if any one can help me to know where is this port ,where did them put it ???:-\
Re: hello All i have question about omega A 2.0 GL 1987
« Reply #1 on: 21 March 2012, 14:15:32 »
Under bonnet near suspension turret
omegaly
  • libya
« Reply #2 on: 21 March 2012, 18:05:07 »
Thank you so much another quetions is this obd 2 or obd can ?
doz
  • Southampton
  • LC,GSi Carlton,Omega Elite
« Reply #3 on: 21 March 2012, 18:09:00 »
Try tech-1  ;)
    • 530D M Sport, 330i Coupe
« Reply #4 on: 21 March 2012, 18:43:00 »
Try tech-1  ;)
Indeed it's an ALDL connection IIRC
omegaly
  • libya
« Reply #5 on: 21 March 2012, 20:10:05 »
Try tech-1  ;)
last questions
is there any usb cable i can used direct from car to laptop ?
if yes
please give name of that cable
doz
  • Southampton
« Reply #6 on: 21 March 2012, 20:23:50 »
You can buy a converter lead to change the interface from the 12 pin on your car to the later 16 pin OBD 2 pin. Now I've got one but as of yet haven't tried it with the software I've got. So don't know what systems will work. I also have a Tech 1 with a mass storage cartridge which has nearly all the vauxhall range from that period, however i feel you maybe some distance away from me. You can carry out a "paper clip" test on your car and by counting the flashes of the EML light work out the codes stored in the ECU. However you can't erase the codes and will not be able to tell which ones are current and which ones are old.
freecall666
  • looking over your shoulder
    • 2.0l sweat tank on wheels
« Reply #7 on: 21 March 2012, 20:33:11 »
Try tech-1  ;)
last questions
if yes
best chance is ebay look for tec1 you may be lucky and find one near to you in your own country as not many post from uk to your country. there was alot of carlton readers on there.
Solar charger fitted.
If not Broke dont fix it..
omegaly
  • libya
« Reply #8 on: 25 March 2012, 21:50:14 »
hello
i my question after last one
any one can check this if it will work with my car
Opel omega 2.0L GL 1987
http://www.amazon.com/ElmScan-Compact-OBD-II-Diagnostic-Software/dp/B002PYBZJO/ref=pd_bxgy_p_img_b
So tell me is ok to buy this .
Best regards for all
Murph
  • Dartford, Kent
    • 2.5 Estate
« Reply #9 on: 25 March 2012, 21:53:10 »
That will not work on the Omega A I'm afraid.
omegaly
  • libya
« Reply #10 on: 25 March 2012, 22:19:18 »
i am from libya
i can order anything from usa to libya
if you can help me to find any thing will work with me on amazon or ebay that
will be helpful to me
Best regards
doz
  • Southampton
« Reply #11 on: 25 March 2012, 23:22:19 »
You need one of these.
http://www.ebay.com/itm/TECH-1-VETRONIX-SCAN-TOOL-GM-FORD-CHRYSLER-SYSTEM-KIT-/180850516650?pt=Motors_Automotive_Tools&hash=item2a1b87e2aa&vxp=mtr#ht_903wt_1270
But you also need the right cartridge to go with it. The Tech 1 is quite rare in Britain. You may have to buy the unit from the USA then search for a cartridge from Germany but they don't come up very often. If you can find what is called a Mass storage cartridge you will get all the Vauxhall/opel cars from that period. However this is even rarer.
omegaly
  • libya
« Reply #12 on: 27 March 2012, 21:17:04 »
this not what i am looking for it this for some one have to open service center
i need some thing sample i can connect it with me pc or laptop and plug it in my car
i mean cable for my one car
and I will be grateful if you give me   type of connector in my car
is obd-can bus
or obd II
what is Iso used with it
Murph
  • Dartford, Kent
    • 2.5 Estate
« Reply #13 on: 27 March 2012, 21:22:37 »
The connector is called an ALDL connector, but there is NO simple software to connect it to your laptop.
What problem do you have?  Maybe we could help?
« Reply #14 on: 28 March 2012, 07:50:51 »
iirc you can short pins a and b in the connector, and use the fault light to flash out codes like you can on an omega too.
Google for exact details, on the topbuzz website if memory serves correctly
Page created in 0.024 seconds with 20 queries.
