Author Topic: help needed please  (Read 5075 times)
brian36
  • Milton Keynes
  • 2.6 mv6
help needed please
« on: 21 March 2012, 16:44:07 »
hello to all!
three wee problems i need help with,hope wee anyway!
1. had recent oil change at local garage ,a few days have gone by but have noticed some cream on filler pipe and cap,none in expansion tank and none on oil dipstick.
2. last couple days temperature needle takes its time,car heats up etc heat in blowers but expansion tank mid to low when cold but after running short time almost at top and bubbling,hoses very hot top and bottom.
3. central locking, i assume i need door solenoid(drivers) as past posts similar i think. you can use remote to unlock all doors excepty drivers,deadlock works,but drivers door until today only operate by key and pop up button sticking sometimes but today after locking car went to get something and now drivers door wouldn't open at all.
eventually got drivers door open hold key to right after click and lift handle, door pin still stuck down.
so any help much appreciated firstly i guess need drivers door solenoid,so if any members have one can you drop me a line.just to say its a facelift 2.6 mv6.
thanks to all! :)
oh and if there's any members in or around fife that know how to rectify my probs drop me a line ok ,cheers :y
Elite_L0ver
  • Eastleigh, Hampshire
  • On too Omega #2
    • 99 2.5 V6, 03 2.2 CD FL
Re: help needed please
« Reply #1 on: 21 March 2012, 16:53:06 »
hello to all!
thanks to all! :)
1) have you got any oil in plug wells oil leaks etc
2) Soundslike you got air in the system somewhere try burping it guide in maintenence section and sounds like your oil cooler leaking water is there any water in your passanger footwell
3) cannot help with 3rd problems hope above helps
Likes My Music LOUD!!!!
Elm327 code reader And OP COM available Locally PM Me
brian36
  • Milton Keynes
  • 2.6 mv6
« Reply #2 on: 21 March 2012, 16:54:24 »
will have a wee look,cheers
noel
  • frome somerset
  • i feel the need for speed
    • 02 omega 2.6 v6 cdx auto
« Reply #3 on: 21 March 2012, 16:58:13 »
hello to all!
thanks to all! :)
1   quite normal for a bit of mayo on filler neck.usually short journeys and cheap oil, suggest using gm 10/40 semi synthetic. ;)
2   thermostat may be lazy or stuck open imho  :y
3  sorry cant help you with this one but im sure one will be along soon who can.
brian36
  • Milton Keynes
  • 2.6 mv6
« Reply #4 on: 21 March 2012, 17:36:55 »
so just been out again,
no water in pax footwell, heaters seems to be fine all hoses seem fine squeezed all i can see,top and bottom hose causing burping so guess they ok
did notice one thing out of place and not being mechanical will try describe.
it if facing car at rear of plenum on right side right up against back at top righ corner its a multi plug with a metal clip and looks like maybe 2 thin wires from, this is broken,that is it is loose and the bit thatr should be attached to engine is not its half joined on to wire section, it is exposed and you can see what looks like 2 terminals and a don't know what you call them micro something,hope someone can figure out what i mean
thanks
hi just noticed a photo that shows bit to top left in picture top left outside square you can see metal clip
http://images.omegaowners.com/images/guides/v6_cranksensor_replacement/Crank_sensor_connector.jpg
« Last Edit: 21 March 2012, 17:49:17 by brian36 »
« Reply #5 on: 21 March 2012, 18:52:33 »
thanks
Connector for the rear multi-ram solenoid
brian36
  • Milton Keynes
  • 2.6 mv6
« Reply #6 on: 21 March 2012, 20:11:29 »
hi just incase have circuled the part thanx
« Last Edit: 21 March 2012, 20:13:49 by brian36 »
« Reply #7 on: 21 March 2012, 20:12:20 »
file:///C:/Users/brians%20computer/Desktop/Crank_sensor_connector.jpg
Link not working
brian36
  • Milton Keynes
  • 2.6 mv6
« Reply #8 on: 21 March 2012, 20:14:25 »
sorry trying to figure out how to get photo on
« Reply #9 on: 21 March 2012, 20:16:34 »
If you mean the connector circled yellow, it`s the rear multi-ram
brian36
  • Milton Keynes
  • 2.6 mv6
« Reply #10 on: 21 March 2012, 20:19:21 »
boy am i glad you did that i was pulling my hair out
thanks
« Reply #11 on: 21 March 2012, 20:20:12 »
thanks
;D ;D :y
brian36
  • Milton Keynes
  • 2.6 mv6
« Reply #12 on: 21 March 2012, 20:22:43 »
now that you helped maybe can i ask what that does? i know im not the brightest bunny but what can i say. hopefully hotel21 can help when he has time but in meantime i need to find parts etc many thanks :y
brian36
  • Milton Keynes
  • 2.6 mv6
« Reply #14 on: 21 March 2012, 20:32:18 »
thanks very much,i think i need help!
and looking at the piece that's left another rear multi plug i hope you can get the bit that's attached engine or im guffed.
thanks
