Author Topic: eml flashing HELP  (Read 7364 times)
bigfoot55
  • South Lincs, (near Holbeach)
    • omega elite 3.0 v6 2001
eml flashing HELP
« on: 24 March 2012, 14:19:40 »
Hi, help needed please  EML flashing when engine is running, did the paper clip test and got code 73, changed mass air flow sensor for new one, still got flashing EML, flashes quickly at idle speed but flashes slow to light all most being on constantly as revs rise, any help grateful recieved, loathed to take it to vauxhall garage, but running out of ideas HELP PLEASE :D
omega 3.0 elite 2001
Elite_L0ver
  • Eastleigh, Hampshire
  • On too Omega #2
    • 99 2.5 V6, 03 2.2 CD FL
Re: eml flashing HELP
« Reply #1 on: 24 March 2012, 14:24:30 »
Might be forget bulb flashing but where do U live maybe someone near you has a tech 2• or code reader to have a look do the paperclip test again or try pedal test  :y
Likes My Music LOUD!!!!
Elm327 code reader And OP COM available Locally PM Me
  • Auckland
    • Mazda MPV
« Reply #2 on: 24 March 2012, 14:46:53 »
Do you still have a code 73? (and no new codes). (without a code reader the old codes won't go away for some time after the fault is fixed)
If so you should be looking for damaged wiring or something having been unplugged.
The other possibility is that the plug to the MAF has been swapped with the plug to the solenoid on the bagpipes
« Last Edit: 24 March 2012, 14:50:08 by Andy H »
« Reply #3 on: 24 March 2012, 22:47:53 »
Does the engine actually run? The one time the EML flashes on a 3.0l is immobiliser, which would prevent starting...
bigfoot55
« Reply #4 on: 25 March 2012, 10:23:06 »
Hi, yes engine runs and starts, does the eml not stop flashing once the fault has be sorted and just remain as a stored fault code ?
« Reply #5 on: 25 March 2012, 13:06:30 »
bigfoot55 - can you describe the light, as the EML does not flash (except the immobiliser fault, already discounted as the car starts), and on a 3.0l, the EML is either on solid, or its off.
Where are you, if near me, will happily plug the tech2 in :y
doz
  • Southampton
  • LC,GSi Carlton,Omega Elite
« Reply #6 on: 25 March 2012, 16:50:53 »
I once had a flashing EML light on a Mk3 Astra. It was accompanied but a series of sudden jolts. Turned out to be the CPS.
  • Auckland
    • Mazda MPV
« Reply #7 on: 25 March 2012, 18:38:55 »
Silly question.. have you still got the paper clip in the diagnostic socket?
bigfoot55
« Reply #8 on: 25 March 2012, 21:21:16 »
Hi,  paperclip has been removed  i think !. Hi theboy  thanks for the offer :y but a bit far from me with car unkown fault. the light description  i would say its flickering fast at idle. as you rev it the flickering slows down and the light is more solidly on , if that makes any sense. any recommendations for a fault code reader there seems loads on the market  maxiscan ms 509 any good, looks like it covers most things. paper clip test done again still showing 73 nothing else.
« Reply #9 on: 25 March 2012, 21:27:35 »
A flicker then?
When you do paperclip test, you are getting:
12
12
12
73
73
73
12
12
12
only?  Any 31 or 19?
dazzerM
  • Reading
  • Mokka 1.7CDTI, BMW 120D Shadow (It’s a work car)
    • Which ones closest
« Reply #10 on: 25 March 2012, 21:33:22 »
I would test the alternator, if the light is changing how quikcky it flickers from Idle to the engine being revved that would be my first point of call and take it from there  :y
Darren
bigfoot55
« Reply #11 on: 25 March 2012, 21:36:20 »
Hi, yes just 12s & 73  :) , will test alternater did not think of that, thanks
bigdods
  • Brackley
« Reply #12 on: 25 March 2012, 21:38:03 »
My 3.0 f/l Elite flashed the light when I had a code 19. For about 10 miles (from M1 exit to brackley) all down the A43 it was flickering, then going out, then staying on for a bit... repeat for 10 miles. Eventually it just stayed on (just about when I reached Brackley).
Perhaps something peculiar to code 19 as I had known I had the 19 for a while following regular paperclip tests but it hadnt thrown then light until that point. New crank sensor problem solved of course.
« Reply #13 on: 25 March 2012, 21:39:32 »
Was the engine running or off?
bigfoot55
« Reply #14 on: 25 March 2012, 21:43:15 »
engine off, should it be with engine running ?
