Author Topic: wheels  (Read 5309 times)
bored bigyin54
  • south wales
    • black beast
wheels
« on: 25 March 2012, 12:20:38 »
hi guys just tried to take my back wheels of but they are stuck solid what can i do to loosen them thanks :y :y :y :y
Elite_L0ver
  • Eastleigh, Hampshire
  • On too Omega #2
    • 99 2.5 V6, 03 2.2 CD FL
Re: wheels
« Reply #1 on: 25 March 2012, 12:24:08 »
Give it a 'gentle' tap with your foot either side on the tyre
Likes My Music LOUD!!!!
Elm327 code reader And OP COM available Locally PM Me
bored bigyin54
  • south wales
    • black beast
Re: wheels
« Reply #2 on: 25 March 2012, 12:27:38 »
tried that wont move at all :y :y :y :y
Re: wheels
« Reply #3 on: 25 March 2012, 12:55:41 »
When mine were stuck on i kicked them from the back underneath the car , had to use some force though  8)
bored bigyin54
  • south wales
    • black beast
Re: wheels
« Reply #4 on: 25 March 2012, 12:57:10 »
tried it from all sides bloody cars simple job off taking a wheel off grr >:( >:( >:( >:( >:(
Dr_X
Re: wheels
« Reply #5 on: 25 March 2012, 13:00:33 »
OMG........ :o bet that was slightly worrying.
Dr_X
Re: wheels
« Reply #6 on: 25 March 2012, 13:02:23 »
It will come..... just got to keep kicking one side then the other til it gets loose...
Re: wheels
« Reply #7 on: 25 March 2012, 13:05:06 »
Yes i wouldnt recommend doing that without axle stands and of course impossible at the road side with a flimsy jack  8)
OOMV6
Re: wheels
« Reply #8 on: 25 March 2012, 14:09:52 »
Loosen bolts just a little, then let car down abruptly - works if you have a trolley jack. The weight of the car should loosen it up
Re: wheels
« Reply #9 on: 25 March 2012, 14:10:04 »
Had this when I first bought my Elite - used large lump of wood (4"x4") and a sledge hammer.  Worked for me  :y
Clean the wheel and hub up and copperslip before refitting wheel - you'll have no more problems with removing wheels ;)
Re: wheels
« Reply #10 on: 25 March 2012, 14:54:44 »
Its a problem with alloy wheels. Always lightly grease before fitting.
On TBE, I tried everything, and ended up undoing all bolts one side, lowering it back down, and flooring the throttle.  Very dangerous, as the wheel can fall off.
Re: wheels
« Reply #11 on: 25 March 2012, 14:59:29 »
I've had to do the same thing to remove an alloy from a car. Dangerous? Depends how fast you go. I did it on my 25' long drive so as you can tell, I wasn't exactly speeding when I jumped on the brake. It worked though.  :y :y
ffcgary1
  • Mitcham,Surrey.
    • Omega Estate/ jaguar XJ6
Re: wheels
« Reply #12 on: 25 March 2012, 17:17:36 »
Use a bock of wood in the inside of the wheel rim and hit with a large club hammer, it will come off just be careful to hit the block of wood not your hand or rim.
Use a wire brush or a circular wire brush in a drill and clean all the hub surfaces and coat with a liberal amount of cooper grease before re fitting.
Jaguar XJ6
Re: wheels
« Reply #13 on: 25 March 2012, 18:22:58 »
As I said ^^^^^^  ;)
Re: wheels
« Reply #14 on: 25 March 2012, 19:27:39 »
I loosen the front ones on the brakes, rears under acceleration ::).  I've had a rear come off, oppsie.
