Author Topic: Gear shift  (Read 1370 times)
Bob G
  • Gloucester
Gear shift
« on: 28 March 2012, 13:52:51 »
Hope I can explain this properly, twice today on starting the car I have pulle on the lock on the auton shift to release the shift to select gears, and twice it was stuck and not moving.  In the end I had to call AA, who got in and by forcing stick forward released it.  Suggested that on getting home I leave it in N but you have to put it in P and relse the catch to get keys out. So what it my problem?
2.0L  x reg GLS Auto
0795omega
Re: Gear shift
« Reply #1 on: 28 March 2012, 13:55:31 »
you do know you have to press the foot brake at the same time to release it i take it?
Re: Gear shift
« Reply #2 on: 28 March 2012, 13:56:07 »
Well, the AA guy should Please read the manual. >:( No need to force the stick, as there's a little catch under the gearstick boot that can be used to release the lever in an emergency.
Do the brake lights work? Often a failed brake light switch can cause this.
Bob G
  • Gloucester
Re: Gear shift
« Reply #3 on: 28 March 2012, 14:39:53 »
Kev
Forced was probably not the right word pushed it forward might be better, never heard about applying footbrake before, unless I have done it sub conscioulsy but yes you are correct ;D ;D what is embarassing is all the yeras with an auto and I do this Doh
« Last Edit: 28 March 2012, 14:43:31 by Bob G »
Re: Gear shift
« Reply #4 on: 28 March 2012, 14:42:19 »
 Releases the yellow lever controlled by a solenoid energised when footbrake applied
